Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 My TT36 will not start,HELP >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 03-03-2009 | 08:01 AM
Default My TT36 will not start,HELP
Hi all, can someone help me, I have put a TT36 engine into my old Kyosho Concept 30. But the needle settings have moved, high & low needles. I have tried lots of times with low needle at 2, 2 1/2 & 3 turns out & the same with the high needle, but no matter what I do I just can not get the engine to start. Please Please can someone give some sort of info on wear I can start from.
Old 03-03-2009 | 09:06 AM
Default RE: My TT36 will not start,HELP
Hi
When you try and start it, does it at least "pop" or sound as if it wants to start?
Have you tried a different (correct) glow plug? The glow plug might be dead.
Is your glow driver fully charged? Otherwise no glowing plug.
When you turn the engine by hand do you feel compression? No compression, no ignition.
Is your starter turning fast enough? If not, the engine won't fire up.
Does the engine get fuel, when you crank it, does fuel flow through and go into into the carb?
Hope that helps a bit.
Old 03-03-2009 | 01:07 PM
Yes, good glow, fuel getting to the carb & it turns over fast. I need to know what to set the high & low needles as thay are all out.
Old 04-04-2010 | 10:56 AM
Did you get your engine started? Ihave the exact same problem.
