RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Head speed?????????
Old 03-24-2002 | 10:41 PM
Default Head speed?????????
Hi guys this is my first time to this board......
I am installing a head speed governor to my Ergo 60 but I need to get the head speed RPMs. I read about setting up a bike computer pick-up to the main grear and using a wheel size of 1667mm. Take this speed x10 and this is the RPMs..
Has anyone of you ever had luck doing this???? And being that the magnets (3) for the governor will be mounted on the main gear, any ideas on where to mount the magnet for the computer pick-up???
Old 03-24-2002 | 11:40 PM
Hello,
I guess I don't understand why you need a tach and a governer. You program in the headspeed you want to maintain in to the governer.
Old 03-25-2002 | 12:14 AM
Default Govenor
What kind of govenor is this that your trying to mount???
Old 03-25-2002 | 12:24 AM
JohnVH's Avatar
My Feedback: (38)
Its not the futaba!!! it only needs one magnet.
My futaba is very accurate, tached it and its right were it says it is.
Old 03-25-2002 | 01:40 AM
sound like a helimax or graupner speed govenor.
i set my speed with a tachmeter (unforunatly not cheap, but easy)
mounting: (i do not know about helimax) but graupner magnets are mounted at the main shaft, with a little collet, real easy, simple and fast.
i asume helimax is the same.
Ergoman, give more specs
Old 03-25-2002 | 02:49 AM
It is a Heli-Max. There are three tiny magnets that mount to the main gear with silicone. I need the tach to set the goverenor up to the right head speeds.
Old 03-25-2002 | 03:24 AM
JohnVH's Avatar
My Feedback: (38)
only silicone? you sure no epoxy?
Old 03-25-2002 | 03:34 AM
Instructions call for either silicone or epoxy or CA. It calls for three 3/16 holes to be drilled in the main gear, (120 degrees from each other), for the magnets to set in....
Old 03-25-2002 | 03:48 AM
whats the diameter of the shaft? if it is 10mm you can get a mount from graupner (4448.104 Sensor mount for governor $29.62). safer, easier and 100% 120 degrees !
Old 03-25-2002 | 04:00 AM
It is a 10mm, had to check... How do I go about getting one of those collects?????
Old 03-25-2002 | 04:26 AM
http://www.v-eastonline.com has them here in the states. i do not guarantee (see disclaimer below) that it will work with your heli and magnets! but i am pretty certain it will. magnet size 5mm dia/ 1mm thick. mount 20mm overall dia / 6mm thick.
hope that helps
Old 03-25-2002 | 06:00 AM
Thanks for the great idea, you have been very helpfull......
