RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Field Force 9 question
Old 06-30-2003 | 01:48 PM
Default Field Force 9 question
i just started today visiting forums..especially rcUniverse
wauw its cool !
this is my first post, well lets go
Im thinking of buying a FF9
but standard there is a click in the throtle stick..
someone know how i can get it out ?
while i can not order the transmitter without it. thx!
Old 06-30-2003 | 08:54 PM
Default FF9
The CHP doesn't click, the CAP does. If it's the same as the FF8, you can flip over the metal arm that rubs the throttle cam and it will elliminate the click on the airplane Tx.
Old 06-30-2003 | 08:58 PM
clear enough
but can I open it
and if
from top or bottum
Old 07-01-2003 | 12:23 PM
Props-n-blades's Avatar
Indeed there is no click in the CHP. If you want to open the transmitter anyway, its mentioned in the manual how to do : "First, remove the battery cover on the rear of the transmitter. Next, unplug the battery wire, and remove the battery and RF module from the transmitter. While you are removing the RF module, pay attention to the location of the pins that plug into the back of the module. Next, using a screwdriver, remove the four screws that hold the transmitter’s rear cover in position, and put them in a safe place. Gently ease off the transmitter’s rear cover."
You can change the tension on the stick if necessary.
Old 07-01-2003 | 02:14 PM
thanks a lot
thats very clear !
