Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
OS .32 proper engine temp >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 07-21-2003 | 02:57 AM
Default OS .32 proper engine temp
I have about 1.5 gallons of 30% Cool Power through my OS .32. I'm trying to get is running right. I have an IR non-contact thermometer. I was wondering what the correct temps should be after hovering for several minutes and when just at idle.
Old 07-21-2003 | 06:51 AM
According to OS there aren't any "correct" temps. You tweak to meet your requirements and as long as there are no obvious signs of overheating (you have smoke and the engine doesn't start losing power) that's the setting you use. After that you check your temp and that's the reference you want to use for your setup. After my "normal" flying (mostly "cruising" around the yard, 80 deg air temp) mine runs around 260 using 20% with a OS 8 plug and set a little rich .
Old 07-25-2003 | 09:09 PM
CURTIS YOUNGBLOOD HAS SOME GOOD INFO REGARDING ENG TEMPS ON HIS WEB SITE BASICALLY ENG BACK PLATE TEMP IS A GOOD INDICATOR OF ENG RUNNINHG TEMP.
REGARDS
