Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 rpm's are my final issue >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 08-07-2010 | 10:19 PM
Default rpm's are my final issue
hk 450 issue: (once this is resolved i will hopefully have my maiden flight with this thing)
I dont seem to be getting enough rpm's out of my motor to lift my bird off the ground. i programmed my esc with a programming card, and i did exactly wat nuttcaze (from youtube) did on his video in terms of programming. is there something on the card i need to do differently in order to get the power?, because my motor has the specs needed
Old 08-17-2010 | 10:07 AM
Default RE: rpm's are my final issue
Some speed controllers need you to program the throttle range, by moving the throttle from 0 to 100 percent. You'll need your ESC instructions to do that.
Also, if you're using a programmable radio, make sure your throttle curve and pitch curve is set up correctly.
Old 08-18-2010 | 11:22 AM
midntpumkin's Avatar
post up what you have , what are the throttle curves , what do you have as pitch when you have 3/4 throttle . your pitch may be too negitive to make it lift off . do you have a pitch guage to check it . need more info to help
