Shuttle Plus problems
Hi, I just purchased a Shuttle Plus (this is my first heli.), and have been assembling it the past few night with no problems. However, like usual, I have ran into a problem. I spent an hour and a half last night trying to get the tail rotor belt around the drive gear (above the cluch, which I'm sure you all know already). I finally got it on after some persuasion, but it is REALLY tight. I have no room to loosen it at all!!
Also, when I spin the rotor head, it's not smooth. I thinks its the belt from being so tight. Help!! I don't want to get any farther before I figure this out. thanks! |
About the above post, I don't mean to sound pissed or anything. I understand that this is a learning process, but I get impatient. I just hope I didn't wreck the cluch shaft or bearings by trying to fit this tight belt.
Oh, one more thing :) I also noticed that there is a bit of binding when moving tail blades for rudder. The screws are not overly tight, but still feels 'tight'. Again, I am just trying to get this right the first time!! |
Shuttle
As far as belt tension goes, it sounds like you have not pushed the tail boom in as far as it will go. Sometimes you have to give it a little nudge to bottom it.
also, make sure you have the proper mesh between all the gears. |
thanks, Wringer!!
that is exactly what it was. And actuall, there was a bit of 'flashing' preventing the tail from being inserted all the way. thanks again!! |
| All times are GMT -8. The time now is 07:58 AM. |
