Ken,
If you're using the 33" boom and carbon rod (part#0968-10) from the Extreme kit, my manual states the rods (part#0868-7) should be inserted 26-26.5mm into the carbon rod. It doesn't mention how much is sticking out. The ball links are to be threaded down 7mm. Hope this helps. Raymond |
34 5/8 " from center ball to center ball with the 33" boom, i am sure you can figure the rest out...
| All times are GMT -8. The time now is 12:19 PM. |
