RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Remote Glow Plug driver (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/177956-remote-glow-plug-driver.html)
MUISER 06-28-2002 04:29 PM
I recall seeing an article a while back that showed how to build you own remote driver using an old glow plug. Does anyone remember where that may have been? Thanks Ron
FLYBOY 06-28-2002 06:59 PM
I used to do them that way, but it is way better to just spend the $5 and get one. They work way better and don't come apart like the home made ones. The solder doesn't seem to be able to take the vibration.
LSP972 06-29-2002 03:06 AM
The Thunder Tiger remote glow adapter, aside from being the best of the several types I've tried, costs around $10.
How much is your time worth to you???
What you're looking for is on Fritz Blackburn's site; sorry, dunno the URL. Do a Google search for "FritztheCat.com", or some variation of that.
Steve
JingYou 10-15-2002 01:00 PM
I've recently purchased a remote glow adapter from thunder tiger, which is a raptor series.
The problem is i dont know how to connect the other end to the glow plug
FLYBOY 10-15-2002 01:18 PM
Is it the clip that is shaped like a U? If it is, slide it on the end of the plug and the bent part that makes a gap between the wires is where it rests on the plug. Otherwise, it is the kind that pushes on and turns about an 8th of a turn to lock it.
JingYou 10-15-2002 01:23 PM
http://rotor.com.sg/cap23021.jpg
Only the left 1, right dont have..
FLYBOY 10-15-2002 01:30 PM
The glow plug in the picture is not the one that goes in the engine. You make a mount to it, mine is down by the gear. The should have given you a bracket made of metal that the plug with the wire goes through, and the nut goes on to hold it. I put the other end of that bracket to the bottom engine mount screw. It has to be conected to the outside of the engine so that works the best. The silver end goes on the engines glow plug. Install a good glow plug in the engine, and on top is the tip of the plug sticking up. Slide this wire clip on the top of the plug starting at the opening on the clip by where it connects to the wire. Just slide it half way on the clip, if you slide it to the end, it won't stay. The clip lays across the top of the head of the engine. Let me know if you can't get it and I will take a picture of mine and send it to you tonight.
Email [email protected] if you have questions.
JingYou 10-15-2002 01:36 PM
Do please email me the picture or post it up here, my email is [email protected], please do send me a pic of it !
ifly-RCU 10-15-2002 07:51 PM
glow plug no good
use a bannana plug, used for conecting your audio up to your tv
radio shack has them
cheap and you can make 2(cut cord in half)
works great!!
HELIHEAD-RCU 10-19-2002 02:04 PM
Remote glow
I agree. Ihave used several of these and the TT is the best one I have found. Well worth the $8 mine cost.
HELIHEAD
