RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Violent Shake (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/402273-violent-shake.html)
Gary Travis 12-06-2002 05:04 AM
Violent Shake
I have a problem with a voyager e the heli lifts from the ground and about 30 seconds into a hover the tail apears to be moving up and down violently to the point were I have to bring it down asap. I have checked the pitch it is -5 +8 +12 as per the manual the throttle curve is ok also I have checked everthing that I could think of and have not solved the problem. Am I missing something? Any advise would help. I am not new to helis although this is my first electric and I have not encountered thi problem before.
WLJ 12-06-2002 07:52 PM
Violent Shake
Hello, The Voyager E is very sensitive to Head speed. Anywhere close to 1300 it wobbles. Crank it up a little and try that. What motor, ESC, that kind of thing? WLJ
Gary Travis 12-06-2002 11:45 PM
Head Speed
I am not sure what you mean by crank it up a bit, I have the throtlle set at 0 low 80 half and 100 full trottle. if you try to go to full throttle that is where the problem is.
WLJ 12-07-2002 12:03 AM
Violent Shake
1 Attachment(s)
If you hover at half stick, decrease the pitch at halfstick a little so it will require a little more headspeed to lift off. Do you have a Headspeed tach? When i first started with the V-E, I was using the stock setup(motor/ESC) on 8cells. Never had a problem with harming the ESC, until I pluged the charger into the ESC. I let the smoke out of that ESC. Later went to Hacker B40-8L on one and B40-7L on the other.(Had 2 V-Es) Even with the upgraded motor and ESC I knew it was time to land when the batteries got low and the wobbles started. WLJ
Gary Travis 12-07-2002 12:16 AM
Headspeed
I think that the problem may be in the ESC as you have tto go to 100% throttle in order for the heli to lift, if I am lucky it will come up about2 feet intill the battery comes down. Also it seems to eat batterys real fast about 2 minutes. I am using 7 cell 3000mah batterys and get the same results out of all four batterys.
WLJ 12-07-2002 12:28 AM
Violent Shake
I don't have a V-E manual right now, but the pitchs seem a bit high. I think you will find quite a bit of difference if you decrease your pitches first (-2,+6,+10) with 7cells. The biggest difference will be going to 8cells with the stock setup. I've got an extra stock motor and a NIB Stock ESC, I'll let you have at a really good price should you need one. Stock motors burn brushes so bad. Did you buy this setup new? WLJ
Gary Travis 12-07-2002 12:49 AM
problem
I did buy the set up new and as I suspected the esc was bad , as far as the pitch settings the manual say -3 + 8-9 + 12. with the new esc it has a lot more power and now wants to lift easily how ever I have to hold full right rudder and the rtudder stii goes right. I dont seem to have rooom to adjust the travel. I am using a futaba 240 hh gyro so I have been told not to use the revo mix, did you use revo mix and if so about how much.
