RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   spinning dragonfly (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/5379872-spinning-dragonfly.html)
broon 02-06-2007 03:13 PM
spinning dragonfly
please help got dragonfly 3ch. worked good for 2weeks, now it wont lift, jusr spins on the ground anti-clockwise
MikeMas 02-08-2007 08:43 PM
RE: spinning dragonfly
Sounds as if your gyro might have gone south. Even though it's spinning, if you hit high throttle will it lift off?
broon 02-09-2007 08:38 AM
what is gyro
broon 02-09-2007 08:55 AM
full throttle + spins faster on the ground.
MikeMas 02-09-2007 09:32 AM
Send me a link to where I can see the heli you have!
Kevinator9 02-09-2007 01:28 PM
http://www.rcuniverse.com/forum/m_53...tm.htm#5387677
here
broon 02-09-2007 03:32 PM
http://www.rcuvideos.com/view_video....7e9393071204b7
this is what i bought. obviously cheapo, but thought i would have lasted longer than 3weeks, but because i bought it over the web. no reply back from seller. so i am stuck with it.
from ebay Item number: 250068613139
broon 02-09-2007 03:35 PM
1 Attachment(s)
here is some photos
MikeMas 02-09-2007 03:38 PM
Ok after looking at the machine, I would guess that one of the two motors has gone bad.
The Hirobo Lama with the same counter rotating set-up will do the same thing after a period of time the motors just wear out. Since both motors have to work as a pair to avoid tourqe - if one motor gets weak, the machine will only spin, which is the reason I asked you if it would lift off the ground.
broon 02-09-2007 03:46 PM
i have only had the thing working for 3weeks. the only two motors it has are the main 1 for the blades + smaller 1 for the tail rotor.
MikeMas 02-09-2007 04:03 PM
Ok I now see its a different ser-up then the Hirobo which uses two motors on the main rotor system - well if it has a tail rotor it has to have a gyro to stabilize it, so it could be either the gyro which is built into the reciever board and more than likely not replaceable or the tail rotor motor.
Is there a trim for the tail rotor on the trans - if so does it make any difference when you move it?
pappy35 02-09-2007 06:37 PM
"What is Gyro" is part of the problem here too. In order to figure WHY something doesn't work you need to study HOW it works a little.
MikeMas 02-09-2007 06:52 PM
Agreed . . .
broon 02-09-2007 09:11 PM
OK guys, got it for some fun. [:o]
broon 02-10-2007 04:16 AM
there is not a separate gyro, so it must be building in. i have tried adjusting the trim + even if i use the controlled to counter act the spinning their is not enough power on the tail rotor to stabalise the spin.
thanks
broon
broon 02-10-2007 02:58 PM
1 Attachment(s)
solution at last, stripped it + noticed the outer shaft connecting lower blades to gears had actually broken at the gear so when the lower blades were turning it was only due to friction + not by the gears, stripped + a bit of glue + i'm back in business, thanks for all of your help.
broon :)
MikeMas 02-10-2007 03:59 PM
Enjoy . .
