RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Strange starting problem. (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/551556-strange-starting-problem.html)
RS2K 02-12-2003 02:21 PM
When I go to start my engine when it is cold something slips in the starting system and the nengine doesn't engage unless I "blip" the starter. when the engine is warm it doesn't do it as bad. I tightened down and re-lock-tighted the starting cup but it still does it. When I took out the engine for inspection I did notice that the clutch will move back and forth a little. I plan on spliting the frames and cutting some plastic to make the bearings tighter.
Could it be my clutch one way bearing that is sliping?
Galifrey 02-12-2003 02:24 PM
sounds like the one way bearing
RS2K 02-12-2003 04:13 PM
Is it possible to change the oneway bearing without changing the clutch? My clutch is about 1 gallon old and has just been broken in. Will it cause problems in the future if I do not replace the bearing? While it is annoying, it is something I can live with.
