RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   qv1 plastic sensor mount (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/61745-qv1-plastic-sensor-mount.html)
vince.b 02-24-2002 09:24 PM
Is there a better one, like a billet aluminum ?.
Scotty740 02-24-2002 10:33 PM
Re: qv1 plastic sensor mount
After I mount mine on the metal arm I put a piece of shrink wrap from the top of the sensor clear down past it on the metal arm. It seems to strengthen it up quite a bit.
vince.b 02-25-2002 12:52 AM
yahh what i did the first time after it fell apart was use dental floss and ca and wraped it. with the new 91 it just could not take the pounding of a rich engine and broke in half this time.
Scotty740 02-25-2002 01:04 AM
Yeah, that is a weak link. I've heard of the dental floss and CA but think the heat shrink tubing is much stronger. You can put one piece over the metal bracket up to the sensor housing covering the screws then another from the top down to cover everything again.
DavidH 02-25-2002 01:46 AM
You can use an optical sensor and mount it to the same bracket. Then all you need is a piece of foil on the bottom of the fan for the sensor to read. You can go to www.runryder.com and search the archives and all the info is there about the optical sensor
David
vince.b 02-25-2002 02:54 AM
who sells the sensor or better yet can i just buy the plastic mount ?.
Scotty740 02-25-2002 12:18 PM
Vince,
I know the sensor housing is available seperatly as I remember someone discussing it. You might want to give the Futaba service center a call.
vince.b 02-25-2002 03:30 PM
I just got off the phone from the service center.... we dont sell the plastic moun...... we dont sell the sensor ether . whats up with that. lame thats all I can say
Scotty740 02-25-2002 03:44 PM
Vince,
This is and old post that I was refering to:
$5 dollars will get you a new outer case for the sensor from Great planes/hobby services. They are quick with delievery too.
Hobby services
Good luck
Maxx-RCU 02-27-2002 03:50 AM
Hey David, how's your optical sensor working? After a bit of trial and error with mounting the foil (I think the foil has the same coating as Bill Clinton...almost nothing sticks to it!) we have the two originals and two more in Shreveport, they all work great! The one I like most is the Futura SE whith the .80...OMG, I LUV this thing...now if I can get the SE with the .60 to smoke I can get another .80 (like I can find another 24 tooth clutch bell...) Chris
