Chicken Sticks
SC
Chicken Sticks
Let’s discuss the Manual Engine Cranking System (MECS), erroneously and popularly known as a “chicken stick.” Now everyone knows neither chickens or sticks can fly, unless you’re referring to the popular Ugly Stick airplane, which flys very well, and is certainly not a chicken, thank you very much. Most R/C’ers think a “chicken stick” is the method you use to start your engine when you are too cheap to buy an electric starter. WRONG!!! A “chicken stick” is the method you use to pin down the last piece of white meat with your fork before your brother gets his grubby little hands on it. A quick look around the table, one fast thrust with your fork, and the bird is yours; as opposed to a lazy look in the sky, a quick flip with the MECS, and the bird is started! As you can see, they are quite different in tools used, method, and desired effect! So let’s keep this one straight: MECS=plane start, chicken stick=food stuff.
Dr.1
Dr.1
RE: Chicken Sticks
aint you usaley afraid of somthing when your "chicken" ? but you realy have to be realy brave (or dumb) to get your hand that close to a spining prop. Hey any one have a good chicken stick resapie they can share
RE: Chicken Sticks
RE: Chicken Sticks
I don't have a 12 Volt power source at my field. Is there an electric chicken stick model that runs off of DC, so I could plug it into my power panel? Also, does it come with banana jacks already installed, or would I have to supply my own?
RE: Chicken Sticks
ORIGINAL: Ron Olson
That's a Chicken stick that you can't use, it's for 110 volt power. Somebody stole my idea already!
HTH
Jim
RE: Chicken Sticks
If you were an old time flier who has regrown the skin on the first two fingers of his right hand many times, you too would call it a "Chicken" stick.
Bill.
Bill.
RE: Chicken Sticks
