RCU Forums
-   RC Humor (https://www.rcuniverse.com/forum/rc-humor-177/)
-   -   Problems and Solutions (https://www.rcuniverse.com/forum/rc-humor-177/638257-problems-solutions.html)
Rcpilot 03-21-2003 01:10 AM
P = The problem logged by the pilot.
S = The solution logged by the mechanic.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: No. 2 propeller seeping prop fluid.
S: No. 2 propeller seepage normal. Nos. 1, 3 and 4 propellers lack normal seepage.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in "altitude-hold" mode produces a 200-fpm descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for!
P: Transponder inoperative.
S: Transponder always inoperative in OFF mode.
P: The T/C ball seemed stuck in the middle during my last turn.
S: Congratulations! You've just made your first coordinated turn.
P: Suspected crack in windscreen.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Radar hums.
S: Reprogrammed radar with words.
P: Mouse in cockpit.
S: Cat installed.
freebird_80_tn 03-23-2003 02:15 PM
Actual conversation overheard from pilot to crew chief
P "I tried it in auto and it worked fine"
CC "Yeah
P "I tried it in manual and no problem there either"
CC "OK"
P "But when I put it in official mode, everything went blank"
CC (after climbing up to the cockpit while laughing as quietly as possible and looking at the switch) "I'll make a note of that sir. Auto and Man work fine, but nothing worked in OFF mode!"
TRUE STORY!
WOW-OOPS 03-28-2003 12:43 AM
When NASA first started sending up astronauts, they quickly discovered
that ballpoint pens would not work in zero gravity. To combat the
problem, NASA scientists spent a decade and $12 Billion to develop a pen that
writes in zero gravity, upside down, underwater, on almost any surface
including glass and at temperatures ranging from below freezing to 300C.
The Russians used a pencil.
Pilotsmoe 03-28-2003 03:03 AM
yep, the $.05 pencil works
Joe Ortiz 03-28-2003 02:18 PM
:p HA HA, keep em coming:D
MinnFlyer 03-28-2003 04:51 PM
P: Noise coming from #1 Engine compartment. Sounds like little man banging on engine compartment door with hammer.
S: Opened #1 Engine Compartment Door. Little Man fell out. Removed Hammer. Replaced Little Man. Closed Engine Compartment Door.
Geistware 03-28-2003 04:59 PM
Keep them coming!
I like this thread :D
WOW-OOPS 03-28-2003 06:52 PM
Airspeed, altitude or brains. Two are always needed to successfully complete the flight.
Gene
Trombe 03-31-2003 08:02 PM
P: Engine won't start
S: Fuel Added
WOW-OOPS 04-01-2003 04:43 PM
You know that your landing gear is up when it takes full
power to taxi back to the pits.
