Solenoid
My Feedback: (98)
Can anyone tell me if there is someone that can rebuild Fuel and Gas Solenoids? I have some from Jetcat that are sticking and also a couple from a RAM that the nipples broke off. Just didn't know if you could possibly get them rebuilt cheaper than buying new ones.
Doug
Doug
You can push the two very small roll pins out of the valve; this allows the valve to come apart and expose the small spring and plunger. You can do anything you need to from there...
Hope this helps,
Jeff
Hope this helps,
Jeff
