JMP Mixture Valve >
JMP Mixture Valve
JMP Mixture Valve
Old 04-09-2002 | 12:27 AM
My Feedback: (14)
Default JMP Mixture Valve
I am adding a JMP Remote Mixture valve to my OS .91's, but don't have the instructions. Do I place the valve before my remote needle, after it, or replace it.
Mark
Old 04-09-2002 | 12:56 AM
Default JMP Remote Mixture valve
Your O.S. 91 should have come with a plug to replace the needle valve in your carb.
Be sure to use LocTite on the plug.
Then place the inflight fuel mixture between the fuel(header) tank and the carb.
JA
Old 04-09-2002 | 01:50 AM
grbaker's Avatar
My Feedback: (29)
Default OS.91 Needle valve
If you can't find the plug that came with the motor, I have been able to get them from Tower Hobbies. You could give them a call.
Old 04-09-2002 | 08:46 PM
Mark- Call JMP at 816-331-0356 in Belton,MO.
Tom Cook is most helpful.
Marty O
Old 04-09-2002 | 10:21 PM
grbaker's Avatar
My Feedback: (29)
Default Instructions
If you can't read these send me an email and I will send you a larger version
