 kingtech >
kingtech
kingtech
Old 10-05-2010 | 06:34 PM
My Feedback: (41)
Default kingtech
whay no kingtech turbine clinic??
Old 10-05-2010 | 08:36 PM
lov2flyrc's Avatar
My Feedback: (24)
Default RE: kingtech
Is there really a need? Ask a question and you will get an answer from either Barry or I....
How can we help?
Old 10-06-2010 | 12:14 AM
marquisvns's Avatar
Amen! Todd
By the way, sorry about the scale of your test stand, the #53 K-170 busted it up pretty bad didn't it?
Barry
Old 10-06-2010 | 12:39 AM
Shaun Evans's Avatar
Wow,
53#?? I thought those Kingtechs were supposed to be light. That sounds more like an anvil to me.....
Old 10-06-2010 | 12:50 AM
Ravivos's Avatar
53# on a 170????
details, please.
Old 10-06-2010 | 01:16 AM
marquisvns's Avatar
ORIGINAL: YellowAircraft
Wow,
yeah, put that in one of your F-15s and it'll still have a lighter wing loading than a full scale of 80#/sqft, did you just come back from tj?
Old 10-06-2010 | 03:06 AM
Hi,
I think putting up a turbine clinic for Kingtech may be something worth considering... rather than having to wait for a reply (yes, I know you guys reply fast), if the problem had been addressed before in a previous thread in the clinic, it can be easily found since all threads related to the engine are inside that same sub forum.
Old 10-06-2010 | 08:42 AM
Old 10-06-2010 | 10:56 AM
My Feedback: (41)
thanks to all. i am very happy with my k-80.. i just wanted to keep up with the latest ecu set up,s oil type and mixture,ect..
Old 10-06-2010 | 11:39 AM
AndyAndrews's Avatar
ORIGINAL: RAPPTOR
Have you tried Diesel in your K80 yet?
Old 10-06-2010 | 12:08 PM
My Feedback: (41)
hi. no deisel yet. im not sure were to get ,clean deisel..kerosene for now. i can get, jet A local. heli fuel ,at the airport..
Old 10-06-2010 | 04:45 PM
ORIGINAL: marquisvns
Wow,
HEY!!!
SHHHhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!! You know I wouldn't go down there again without YOU! But seriously, do you have a 170 that's doing 53 pounds of thrust?
Old 10-06-2010 | 06:18 PM
I think he means production #53.
Old 10-06-2010 | 06:36 PM
lov2flyrc's Avatar
My Feedback: (24)
Misunderstood...
I have been testing K-170E Engine #53. For some reason my scale on the test stand is getting an overload error with trust readings over 37lbs, the K-170 is exceeding this quite easily.
We are still trying to work out the settings for this engine. Personally, I think the engine is a bit underrated, this engine has the ability to produce over 40lbs without any negative side effects ..... #53 has been tested down to 0 acceleration/deceleration setting with no sign of the engine laboring; no coughing or sputtering during acceleration. We have been testing with a new pump model from flightworks and although it seems to perform well, I think there is more potential in the engine than the pump is providing.
Will be testing more on Friday, will let you know what thrust we get out of the engine on a Hausel pump at 125K...
Old 10-06-2010 | 07:31 PM
bevar's Avatar
My Feedback: (27)
Todd,
Are you spinning the K-170 125,000RPM?
Beave
Old 10-06-2010 | 08:01 PM
lov2flyrc's Avatar
My Feedback: (24)
ORIGINAL: bevar
Todd,
Beave
Not currently... so far my tests have been at 123K with over 37lbs at between 83 and 89F ambient.
Old 10-06-2010 | 08:12 PM
bevar's Avatar
My Feedback: (27)
Wow...that's pretty good!
Beave
ORIGINAL: lov2flyrc
Old 10-07-2010 | 04:14 AM
My Feedback: (41)
thank you very much for, takeing "your" time, to give us ,fair accuate data. got my respect,,
Old 10-07-2010 | 11:29 PM
marquisvns's Avatar
Sorry for the confusion, it is #53 not 53#.
Here's another test done on #001, K-170 back in August under intense Southern California sunshine [8D], notice that the temperatures were all well under 600C, nice and comfy
http://www.rcuniverse.com/forum/m_98...tm.htm#9895195 (post #63, NOT post 63 pounds)
Barry
