 Standard servo on 7.2V?? >
Old 12-21-2010 | 10:36 AM
Default Standard servo on 7.2V??
I am building a small model for Lambert Kolibri. In an attempt to make things simple I elected to use High Voltage rated servos on the flying controls (JR DS378HV) direct with 2s Lipo. A change of plan from hand-launch to fixed undercarriage means that I now need a steering servo. I am not too keen on spending $75 on a nose steering servo for this model.
Has anyone used 'normal' servos (such as Hitec 65MG) on 7.2V? If so, how long do they last?
Is there an easy (small/light) way to drop the voltage for the one servo? I have seen the Align step-down but this only drops 0.7v which I'm not sure would be enough.
Old 12-21-2010 | 10:53 AM
saddler's Avatar
My Feedback: (93)
Default RE: Standard servo on 7.2V??
Easy fix. Here's what you need.
http://www.horizonhobby.com/Products...odID=SPMVR5203
Old 12-21-2010 | 10:55 AM
Spektrum makes a small, light inexpensive voltage regulator that works in-line with up to two servos. I installs in-line, and allows the rest of the airborne system to operate on battery voltage.
The part number is VR5203, price US $29.95 ea.
See it on the Spektrum website....
Old 12-21-2010 | 10:59 AM
dubd's Avatar
A fully charged lipo is around 8.4v, which will fry your HS-65. The suggested regulators in the above post is your best bet.
Old 12-21-2010 | 11:11 AM
Thanks guys. That will do the trick
Old 12-21-2010 | 07:27 PM
flyinfool1's Avatar
By the time you get the "cheap" servo and a regulator, you will have almost bought the good servo, and added another failure point plus extra weight of the regulator.
Just a thought.
Old 12-21-2010 | 09:36 PM
reo's Avatar
reo
My Feedback: (130)
also some nice light options here
http://www.smart-fly.com/Products/Regulator/4.htm
