Bickley Jets 2011 - sponsored by Al's Hobbies
#1053
RE: Bickley Jets 2011 - sponsored by Al's Hobbies
Thanks for the message reply Brother Ali,
Me & my friendsorderedFutura modlesto Thomas today. Lets see how fast they ship it to us!!!
We are still confused on using Futaba 10CAG 2.4Ghz radios &power expanders on jets. All we want is to go safe thats it...
How do compare JetCat with IQ-Hammer engines? We respect your advises so its always easy for us to finalize
Great regards,
Syed Haisan Jafri.
Lahore, Pakistan.
Cell # 0092 300 8440 222
Great regards,
Syed Haisan Jafri.
Lahore, Pakistan.
#1054
Congratulations on your order.
The Futaba 10 ch will be more than safe enough for use on jets.
I have never used the IQ Hammer turbine so can not comment. I have used many of the G booster which is made by the same hands as the IQ hammer and can tell you that I received very good service from Didi ( The maker ) whenever I had a problem. For me, I really like the constancy of the Jet Cat turbines. They are always my first choice. Of course I use other turbines, but not as much as I do Jet Cat.
Regards Al
Regards Al
#1055
1 Post
I am no expert on this matter but I understand that the IQ-Hammer turbines use a new very sensitive ECU designed to revert to failsafe in instances where most others turbines would not - be good to explore exactly what this is before taking the plunge to buy.
marcs
marcs
#1056
Thanks Birather Ali & Mr. Marc s,
Any solid words for using power expander Or the power box??? Since now you know I will be using 2 batteries A123 with the futaba R6014HS receiver &total of 8 good hitec servos.
Now the "IQ-Hammer",most attractive words for me were "Maintenance: 50hours" Now performance can be commented only by someone who must have tortured it well...
Regards,
Sunny.
Regards,
Sunny.
#1057
If you are going for A123's and the 6014 have a look at the Orbit Power Jack it has two battery inputs and boost the servo signal voltage to 5 volts, it does not regulate the Rx power or the voltage to the servos, but I have been using the Power Jack with A123's on the 6014 for about two years without any problems.
Mike
Mike
#1058
Just to keep up with the Futura theme, I flew mine back home today > [link=http://www.rcuniverse.com/forum/fb.asp?m=10608657]http://www.rcuniverse.com/forum/fb.asp?m=10608657[/link]
