Tomahawk Futura 2.5m
Looks good Ian, love the union flag look, I did me 1.9 in a F1 scheme, considering doing the big one the same, do you know of any details thread on a 2.5m build it would be good to look at the differences.
#31
Paul
the 2.5 will look great in that scheme! Craig tomahawk doesn't do the winglets for the 2.5 only for the 1.9 so before painting the wings I had some machined bushes made and installed them so the winglets slide into 2 small 3mm tubes in the tips and a grub screw holds them in place! All I did was re size the winglets from my 1.9 .
#32
Originally Posted by [email protected]
Yes I. Sure someone would have done one but having trouble finding it. I'll keep looking.
#37
5mm behind the main spar give me a viceless flight envelope. Although you could move it 20mm in either direction from there and still have safe peformance.
#38
Hi all !
Mine is on the rear side... It sits on the main 3 wheels, but if I put the tail cone in contact with the ground, it will stay on the ground... I like it like that, and if the main gear was more rear, I would have put the CG more rear...
All that with fuel tank empty.
The Futura is more neutral like that and it's a blast for F3A style aerobatics...
#40
Hi friends:
from Spain, a 2.5 Futura with cmjets tanks. 8L kero + 2.8L smoke.
Regards from Spain.
Carlos Marquez
_________________________
www.cmjets.blogspot.com
Regards from Spain.
Carlos Marquez
#43
Hello Champs,
Ordered my 2.5m after having flown 1.9m for about 2 years. Need following info:-
1. Perfect size for servos arms (Ailerons, Elevators, Flaps & Rudder)
2. Good CG location for delightful inverted and knifedge flights
Regards,
Regards,
