 4-40 left hand threaded nuts >
Old 01-22-2011 | 01:42 PM
My Feedback: (32)
Default 4-40 left hand threaded nuts
Where can I find some 4-40 left threaded nuts? I need them for the H9 titanium push rods.
Old 01-22-2011 | 01:49 PM
My Feedback: (15)
Default RE: 4-40 left hand threaded nuts
Mcmaster Carr or Grainger has them.
Old 01-22-2011 | 02:29 PM
My Feedback: (32)
Ok, I looked on Mcmaster, but didn't see them. I must have missed it. I will look again.
Old 01-22-2011 | 03:52 PM
My Feedback: (15)
try Grainger
http://www.grainger.com/Grainger/wwg...headSearch.y=8
Old 01-22-2011 | 05:18 PM
FILE IFR 's Avatar
ORIGINAL: killerG
Yeah, I looked too.
The smallest they offer for left hand threads is 6-32.
Old 01-22-2011 | 05:41 PM
lov2flyrc's Avatar
My Feedback: (24)
Shouldnt really need them... The H9 rods are turnbuckle type; left hand on once side and right on the other. If you nut lock the right hand side, the rod cant turn! No real need to do both ends.
Old 01-22-2011 | 05:42 PM
My Feedback: (85)
ORIGINAL: lov2flyrc
Good point
Old 01-22-2011 | 05:50 PM
Countryboy's Avatar
My Feedback: (25)
ORIGINAL: killerG
Graham,
Just out of curiosity, what type of clevis are you using on each end of the H-9 push rods? The question does have a purpose behind it in relation to your question regarding 4/40 left hand threaded nuts.
Old 01-22-2011 | 06:06 PM
My Feedback: (32)
I am using metal ball links on both ends for the elevator rods on a SM Hawk. I just want to make sure the turnbuckle doesn't move.
Old 01-22-2011 | 06:59 PM
Countryboy's Avatar
My Feedback: (25)
ORIGINAL: killerG
OK,
While the 4/40 lock nut would be the the proper fix to jam the clevis and take any play out of the threads... but is not readily available, why not after setting the initial length of the push rod just solder the left hand threaded clevis or locktite it using the permanent green locktite. After the initial length is set, only small adjustments should be required which can be done from the right hand threaded clevis. I love the H-9 titanium rods, but always hated the fact that one side is left hand thread.
Old 01-22-2011 | 08:12 PM
My Feedback: (32)
Ya, I think I will just use locktite on the LF side and just use a Nylock on the RT side.
Old 01-23-2011 | 08:49 AM
flyinfool1's Avatar
Nuts are pretty easy to make.
[link=http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=1736886&PMT4NO=101419707]4-40 left hand tap[/link]
[link=http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=8250556&PMT4NO=101419744]3/16 Hex Stock[/link] Lifetime supply of nuts.
You will also need a #43 (.089 Dia) drill available at any hardware store.
If you do not have a lathe for cutting the stock, you can use a file, and hacksaw in a drill press.
