Time For Your Input!
My Feedback: (24)
We are in the process of developing several new, innovative items for the jet market. Dont want to spill the beans just yet as to what we are working on however; I would like to hear YOUR desires! What do you feel is missing in the Jet Model accessory market? If we where to produce any product you wish, what would it be?
Give me YOUR ideas! If we decide to produce it, I will send you one for free!
Todd
Dreamworks Model Products
Todd
ORIGINAL: RAPPTOR
Jet kits.builder kits.. like bvm used to make .Not totaly arf. Cheaper gear and struts. Small F-18 .like 15-18 lbs thrust range. Same size F-22...No more boom jets
but I give you a 9 for not using all caps and attempting some form of punctuation[sm=wink_smile.gif]
Todd, how 'bout a generator that uses exhaust gas to constantly top off onboard battteries?
Dumb, I know...but had to close my post with some sort of suggestion
My Feedback: (24)
ORIGINAL: RAPPTOR
My Feedback: (39)
ORIGINAL: ravill
Todd how about a direct mechanism steering nose retract unit? I've asked about this for a while!
Raf
Raf
MAP supplied me with Pro-links from Dreamworks when I ordered the retracts so I don't see why they couldn't work together to supply the retracts thru Dreamworks.
My Feedback: (80)
Todd,
How about Electric or Hydraulic brakes.......would like to get rid of the air pump.
Electric actuated retracts.....I know there are some out there....but some heavy duty ones.
And YES....direct mechanism steering nose retract unit.
Derrick
Derrick
My Feedback: (39)
How about a battery switch/redundancy system specifically for the A123 cells.
I have been running the A123's in pairs with 2 JR heavy duty switches. It would be nice to have a single swtich unit that provided some fail-safe and battery sharing capabilites with no regulator.
PaulD
PaulD
My Feedback: (24)
There are two things I don't like about that one shown. First, there doesn't appear to be anything that keeps the nose gear straight when it dis-engages from the steering arm - that's always a pain to do if it not designed into the gear from the start (maybe it is and we can't see it...). Second, if you are on the rudder with you actuate the gear down, it will miss the steering mechanism and bad things happen (happens on a Kingcat gear, which is similar, and the result is not good...)
I'd prefer a mount for a mini-sized steering servo right on the nose strut.
Bob
Bob
1. How about an "EZ Hinge" or "EZ Cylinder"? Basically somne ingenious simple jig or device nobody has thought of yet that allows you to pinpoint exactly where your cylinders/hinges need to be placed so that doors close perfectly and nice and tight without putting too much pressure on hinge/cylinder and popping them off?
2. While the electric retracts and brakes are being produced, how about An air leak detector, or non-toxic colored gas that shoots out the air leak and lets you see exactly where it is.
Or MRI machine you can put your retracts and cylinders in that show the leaky spot
. Basically, some way to pinpoint leaks exactly without 20 hemostats and a tons of silence so you can listen for where the air is escaping. On that note, an air leak repair kit.
3. Oh and the guys are spot on, a "Universal" direct steering mechanism that has a variety of brackets that let it "bolt on" or "tap in" to most common and mainstream struts would be AWESOME!
Shaz
. Basically, some way to pinpoint leaks exactly without 20 hemostats and a tons of silence so you can listen for where the air is escaping. On that note, an air leak repair kit. 3. Oh and the guys are spot on, a "Universal" direct steering mechanism that has a variety of brackets that let it "bolt on" or "tap in" to most common and mainstream struts would be AWESOME!
Shaz
ORIGINAL: sskianpour
3. Oh and the guys are spot on, a ''Universal'' direct steering mechanism that has a variety of brackets that let it ''bolt on'' or ''tap in'' to most common and mainstream struts would be AWESOME!
Shaz
Shaz
Greg
My Feedback: (106)
How about some very simple caps like this for our quick connectors and a little plastic box to put tjem in to keep the matter off and out of them. I know they can be injection molded faster and cheaper than me stepping them off in my mill. I also put a little dab of your lube in them so when they come off and on it auto lubes the rings. I'm working on the female caps but will be awhile. Roy
My Feedback: (39)
ORIGINAL: rhklenke
Bob
Bob
I do like the direct servo mount units but in a lot of applications there just isn't the room.
PaulD
Yes it does you just can't see it. We tested it for two years now, not one single problem with it after a many hundreds of flights. You only need to stay of the rudder stick for a few secounds when it is retracting. I turn my steering servo of with gear in the up postion however I had one full season on it before I did that. I have sold a bunch of them and not one complant yet.
I have one with the servo mounted to the strut, problem is that most ARFs don't have room for it. I also made prototypes of a nose wheel retract that has the mounting lugs further back and servo comes up on the side of the retract frame. This works much better with models that have full cockpits. But again it will not fit in most ARFs.
John
Todd,
Here are some ideas to consider:
1 - Cheaper alternative of Hysol adhesive
2 - Larger cockpit and cover spring latches
3 - Elecric motor actuated retracts for wheels and smaller ones for doors with separate power supply. Then get rid of all equencers, tanks tubes and valves and rams.
4 - Built-in hopper tank inside the main fuel tank.
5 - Front strut with built in steering (retract-type) motor.
Email me for more details.
Mssa
Mssa
Here would be my suggestions, not in order of preference:
Flame/heat Resistant servo leads or Nomex tubes we can run reg servo wires through. If it came in
a spool and we could cut it to length ourselves that would be better (sized for reg JR type leads)
A good gyro system with pitot tube for jets similar to this but priced better:
http://www.lf-technik.de/shop/produc...-Wing-Jet.html
Blank dry transfer sets that we can print our own graphics utilizing an inkjet printer.
Pre-wired multiplex connectors (male and female) pigtales for batteries
Better UAT for a decent price.
Onboard parachute recovery system for Jets.. compact and deployable at will for various size Jets.
Faster curing Hysol type glue (5 min?)
Automatic safety wire applier, twister, cutter and crimper all in one step (lol dreaming?)
quick connect and discounnect fuel filters (the ones we have now have to twist the fuel line to take appart)
Color coded servo wires (similar to different color air lines) for easily identifying.
Velcro with better adheasive that is fuel proof
<div>
</div><div>Todd here is my list:</div><div>
</div><div>- tool to easily align a turbine related to its pipe.</div><div>- high quality connectors for several servos. (ex: wing) Connector should have a safety so it can't get loose. Connector should have large number of pins to allow for redundancy and support up to 10A per servo</div><div>- more wing bags supporting various wing / stab shapes</div><div>
</div><div>Arnaud</div>
Todd,
A good tubular alum field work stand that can be adjusted to hold both single fin and twin boom jets. Doesn't need wheels but can be broken down easily to stoy flat for transport and isn't made of PVC
George
.George
Agree with George on the field work stand. I have one that I got from Harbor Freight. It works but I sure wouldn't call it good and would certainly pay more for a "GOOD ONE".
ORIGINAL: acw
<div>
<div>
