FEJ F-100F
RE: FEJ F-100F
the FEJ standard quality - poor []
here is my build thread, only a few pics and in german. It´s not much to wrote, the same to do as an every other FEJ oder China model.
The thrust pipe is changed to a lighter from turbo didi, also i changed the 4 fule tanks to one big.
but, look here:
http://www.rclineforum.de/forum/thre...33ab4b2b86f584
but, look here:
My Feedback: (49)
RE: FEJ F-100F
The FEJ F-100F is a excellent flying jet. I found the construction quality to be very good for the cost. My issue was the same as with almost all of their jets ie the LG didn't function properly. Eventually a solution was found which involved placing an individual retract valve and air supply for each strut. Admittedly, a PITA, but I love the way the jet flies, very similar to the BVM F-100.
The landing gear mounts in the wings is structurally weaker than it should be for a jet of this size & weight, IMO, but if you're careful with your landing speed you'll be fine.
David S
David S
RE: FEJ F-100F
Hi David, overall do you think the FEJ F-100 is a good model. The price is very good but my other two jets are from Skymaster.
My Feedback: (49)
RE: FEJ F-100F
ORIGINAL: wop flyer
David S
My Feedback: (34)
RE: FEJ F-100F
You may want to consider changing over to the electric gear from Down and Locked...the control box also has a door sequencer built in to it! I have been using it for the last 5 months and it works perfectly. You will be very happy with the conversion!
Tommy
Tommy
My Feedback: (75)
CA
RE: FEJ F-100F
We have sold several of these kits and they do fly wonderful (including mine!!). As Dave mentioned, there was a problem witht the gear on the early ones but now that the gear is made "in house" things have been fine. I still think Dave is right about the air system or you can have it converted to electric as Tommy has done. I think it's a great idea.
Let me know if you need any help with it.
Lowell
Lowell
My Feedback: (49)
RE: FEJ F-100F
ORIGINAL: dubd
Why not fix these gear so that they operate on one air system?
You'd have to ask that question of James.
David S
RE: FEJ F-100F
I did ask and was told to use two air systems. [:@]
ORIGINAL: David Searles
This may have been accomplished on their newer kits, but, my experience is with one of the early models. I don't know that they changed them. This is just how I finally got mine to work.
David S
ORIGINAL: dubd
David S
My Feedback: (73)
IL
RE: FEJ F-100F
i will tell you i have an FEJ F-100 and was very impressed with the flying... i usually have smaller Jets and this was the first time flying something a little bigger and in the first few seconds i was enjoying it..i put 3 back to back flights on it that day.. The landing was in a cross wind and handled awesome a bad gear door servo made me fly gear down but they did work great.. Down and Locked did my F-14 gear just because i wanted to see what they are all about and they are cool i will post video of that later cool... [youtube]http://www.youtube.com/watch?v=s8jt7bMFT4c[/youtube] [
RE: FEJ F-100F
Hi Bill,
did you fly the original CG 400mm from leading edge?
There is a big difference between the FEJ CG and the Skymaster F100 CG.
regards
Jörg
regards
Jörg
My Feedback: (73)
IL
RE: FEJ F-100F
i get my FEJ,s from Jet Time and so far they seem to to be CG,ed and radio setup up at factory Spec,s .. i tell you i wasn,t afraid of this one at all i always talk about it
My Feedback: (49)
RE: FEJ F-100F
ORIGINAL: Inconel
Hi Bill,
regards
Jörg
[/quote]
Jorg,
I set my CG at the factory recommended location and have never changed it. The jet flies quite well at that position.
The SM F-100 is smaller so a mm to mm comparison doesn't apply. However, the BVM is the same size as the SM and the recommended CG is proportionally about the same on the FEJ. I've owned both the BVM & FEJ and really couldn't tell much difference at all in their flight characteristics. Excellent for both.
David S
Hi Bill,
regards
Jörg
[/quote]
Jorg,
David S
My Feedback: (75)
CA
RE: FEJ F-100F
Joerg,
I did set mine to the factory specs and as Bill said it was right on. The plane fly's like a trainer.
Enjoy it and let us know if you need anything or help with it.
Lowell
Lowell
RE: FEJ F-100F
Dave, just for info, I have designed a custom set of retract walls for FEJ big jets mains. Made from 2025 mil spec aluminium alloy from McMasterCarr and machined to my specifications.
Large bronze axle with fail safe design. Way stronger than the original walls ( not cheap though )...
Been working like a breeze on my heavy metal F-18F for the last year ( and it's been withstanding a couple of hard landings with authority )
RE: FEJ F-100F
Hi Guys, thanks for all the replys and INFO. Problem now is does the model come in a box that the Leader of the OPPOSITION
( The WIFE ) cannot See.
