Solid radio for RC jet flying
Hey guys,
After a long break, I havedecided to get back into RC. I left off just prior to getting into jets. Obviously, I'm not going to jump right into trying to fly jets (although I fly them in real life, I rememberrcbeing slightly differenthehe), but I would like to get your recommendations on a solid RC transmitter setup for rc jet flying.
I tend to buy ahead of where I'm at, and I've looked at a few posts regarding transmitters here, but would love to hear your opinions. Also, is the process still the same for getting turbine qualified as it was five years ago? I seem to remember that you had to fly high performance rc aircraft (eg. fast) and then get a special license accompanied with a "checkride" of sorts by an authorized "check airman". If there's anything else you feel I should be aware of, please don't hesitate to post it!
Anyways, great to be back into the hobby and I look forward to your responses!
My Feedback: (17)
RE: Solid radio for RC jet flying
welcome back to the hobby...........
as for the radios, this might start a war here with a few, but you have to choose what you have always felt comfortable flying, I would only recomend atleast a 9 channel radio, some of the 12 and 14 channel radio, either JR or Futaba are popular with the jet set guys.
and as for the turbine waiver, the biggest change has been that you now have to use a turbine powered aircraft minimum 12lbs to take your waiver test flight
Mark
Mark
Really any of the major brands of radio will do. I personally like the Airtronics 10 channel real easy to program and about half the cost of Futaba or JR. Have at least 70 jet flights and hundreds of non jet flights without any radio problems at all. More a question of personal preference.
I can atest to the value of the Airtronics SD-10. What you get for the price can't be beat. I've been flying it in all my jets since the radio came out a couple years ago and love it.
Chris
Chris
Get a 12 channel radio if you want to "buy ahead". Less channels will work with a more simple jet, but the additional channels will provide you with more programming flexibility and the ability to support a more complex model down the road. Pick the brand that you're most comfortable with. My experience has been with Futaba and JR, both of which have their pros and cons, none of which make one better than the other IMO. Although the upper-end Futaba radios (14MZ/12Z) have nice features like lithium-ion batteries, SD Cards, fully assignable switches, etc. Practically speaking it comes down to personal preference, budget, etc. FWIW, I use a 12X.
FL
I'm planning on substituting the 72Mhz module on my Multiplex Evo for a Weatronic 2.4 system. You just can't beat Multiplex's programming flexibility with Weatronic's solid signal. I also own an Airtronics SD10 but prefer my Royal Evo 12.
ORIGINAL: YellowAircraft
Hi,
I just got a Futaba 12FG, and I'm devoting one day per page to understanding the manual....
Hi,
"Futaba xxZ for dummies" please.
Hi,
Hi,
Shaun, there must be an English tutor in your area to help you move along faster.
Sorry Bud, I had to say it.
Hi,
Hi,
12fg - excellent radio with free software updates. A new update is due very soon with a rumor that there will be a channel increase, which may be true considering they just updated the 8fg to a 14ch on the free update released last week!(12 proportional + 2 digital)
My Feedback: (14)
You need all the channels for ease of set up.
Aelerons 2
Flaps 2
Rudder 1-2
Elevator 2
Throttle 1
Brakes 1 (mandatory)
Gear 1
Rudder trim 1
Gear down trim 1
The minimum for ease is 12 channels, do not use Ys or Matchboxes unless forced to.
Aelerons 2
Flaps 2
Rudder 1-2
Elevator 2
Throttle 1
Gear 1
Rudder trim 1
Gear down trim 1
Gents,
I still use a 72Mhz radio for my jets. The trick is I use a Weatronics receiver that give me 20 programmable outputs. So....I still have my favorite 8 channel radio....Tracker 8 by Aritocraft....with the high tech stuff of weatronics. A good friend uses the same setup but with a JR 9303 radio. The Weatronics give you everything you need.
DW_Crash
DW_Crash
ORIGINAL: Jeremy_D
Mike
My Feedback: (26)
TX
If you buy JR, make sure it has DSMX as DS2 is Sianara, Adios, Tango Uniform...
Futaba, Airtronics, Hitec and DSMX would be fine IMO. I prefer the Hitec Aurora 9 as best bang for the buck...
My Feedback: (49)
The Futaba 14MZ. My kingcat has every servo on an indvidual channel. No Y harnesses and no Matchboxes and one channel left for the smoke system.
Mitchell
Mitchell
ORIGINAL: Redline7000
My Feedback: (18)
ORIGINAL: Mitchell-RCU
Mitchell
Mitchell
Y harness? What's a Y harness?
12FG
Marty
My Feedback: (55)
Hi,
Hi,
BTW, I have each servo on my Skymaster L-39 on a dedicated channel. No 'Y' harness, no matchboxes.
My Feedback: (18)
ORIGINAL: VF84sluggo
I love my 12FG, but brother, if you can understand the manual, you are my hero! Teach me once you figure it out.
Hi,
Hi,
Marty
Gentlemen,
Great information - many thanks! Did some additional research in talking to some of the local jet guys; the overwhelming recommendation was the Futaba 12FG, and not coincidentally, I saw a lot of 12FG recommendations .
Got myself set up with a soon-to-be-soldtrainer jet (I actually saw it fly just yesterday) and I have a fewguys that even offered to help me out when it comes to instruction (a couple of them are actually able to sign off on a waiver when the time comes). The jet itself is very simple no-frillstrainer at a great price (it already comes with the tanks, servo's etc- only missingthe engine).
Iwas glad to see that there are jets out there that you can actually train on (not as a beginner rc guy of course, but as someone who has some decentstick time).Anyways, I'm sure I'll be pestering you guys with my newbie questions from time to time,but I just wanted to say "thanks" for the input you all gave! I'm pretty much a bookworm when it comes to technical stuff, I'll be curious to see what I can make of the 12FGmanual
Best regards,
- Steve
Best regards,
- Steve
