PowerBox or Not ?
My Feedback: (13)
RE: PowerBox or Not ?
Weatronics use a master / backup model for battery redundancy. It will switch to the backup one if voltage drop on master one. You get battery redundancy, just a different one.
Its a reasonable debate which one is better. I'm more used to the dual batt model, but can live with this one in order to benefit of the other Wea features.
ORIGINAL: DelGatoGrande
corect me if i am wrong but as far as i know weatronic use only ONE battery and not TWO like PowerBox that share the load on two batteries
...plus on a powerbox you cant lose a plug need to work the swich cause it doesnt have one.
my 2c
my 2c
The Wea soft swith is a simply "open circuit for on" device as used in most soft switches today. If you don't like the plug system, you can easliy wire in a switch to the circuit.
I agree with you that if you want more than 12 seperate channels, each on a seperate transmitter switch/slider/stick, then the current Wea software will not do it as they have only have 12 inputs and up to 30 outputs. This is fine for me as i dont like that many individual controls, and use the software to group several devices onto 1 switch or slider.
I believe that in the future Wea will be up graded to 16 inputs, and this should be a software upgrade for all the current 2.4
Rxs.
Roger
1 aileron
2 elevator
3 rudder
4 stearing (center when gear is up)
5 flaps
6 slats
7 throtle
8 ecu AUX
9 smoke
10 airbrake
11 powerbox failsafe
12 MPDX1 FUTABA DECODER
13 retracts
14 brakes
15 lights(remote swich)
16 afterburner(remote swich)
17 shute
i use the PowerBox Royal to run the first 7 main vital sufraces
and i use the futaba decoder that can pump out up to 28 ch
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLZH6
sorry but Futaba FASST for me with PowerBox.
cheers
ORIGINAL: David Gladwin
At the moment they are 12 channels only , I guess more will come, in time.
Regards,
David.
Regards,
David.
2 elevator
3 rudder
5 flaps
6 slats
7 throtle
8 ecu AUX
9 smoke
10 airbrake
13 retracts
14 brakes
17 shute
cheers
I just try to connect MPDX-1 to my new Weatronic DR-12-30, it is working. Now, my DR-12-30 becomes a 26 channels system. I think there are enough channels for me.
My Feedback: (23)
guys ...strange thing futaba link stoped working http://www.futaba-rc.com/radioaccys/futm4158.html
and i just learn that Futaba takes MPDX-1 out of the market[X(]
i havent try it on a weatronick and i would not risk it LiKai
