 spectrum ar9000 problem >
Old 04-02-2011 | 07:38 AM
Default spectrum ar9000 problem
hi
anyone had a problem with this rx? i have a new rx and tx module that im setting up on my heli, after binding and setting the throws i moved both sticks in all directions and the rx just came to a halt with all lights flashing, it also went out of bind. the duralite battery shows 7.8 volts on the checker with a one amp load, i swapped the regulator for another too??
anyone else have this problem, if so what was the answer
thanks all
Old 04-02-2011 | 07:51 AM
Default RE: spectrum ar9000 problem
Are you using DSM2 or DSMX?
Old 04-02-2011 | 08:01 AM
rcguy!'s Avatar
My Feedback: (69)
ORIGINAL: 3dean
hi
thanks all
Maybe ask in the Heli forum?
Dave
Old 04-02-2011 | 08:07 AM
hi its dsm2,
Old 04-02-2011 | 08:23 AM
aquaskiman's Avatar
My Feedback: (46)
Check the battery voltage as you load the servos; check it after the regulator before the receiver.
