 Engine test stand help? >
Old 04-15-2011 | 06:35 PM
highhorse's Avatar
Default Engine test stand help?
I'd like to run some thrust tests on the bench, anyone have the hookup on a setup that's a bit more accurate than the "Wal-Mart fish scale"?
Also, I'm looking for conversion data for ambient vs standard temp and pressure........
Oli?
Thanks, Don.
Old 04-15-2011 | 07:20 PM
rcjetsaok's Avatar
My Feedback: (7)
Default RE: Engine test stand help?
Can't help you on the fish scale... If you figure a good one let us know !!!! I have a great test stand that slides on ball bearing rails, but the scale is a Walmart dial type... Not too accurate...
As far as the conversion deal, download this program and keep it on your desktop... Been useing it for years. Easy to use. You can convert anything !!!! Seconds to Light Years, Grams to Tons.... you name it !!!!!
http://wscope.com/convert.htm
Danno
Old 04-15-2011 | 07:52 PM
highhorse's Avatar
I appreciate the input but that's not the sort of conversion I was looking for. Have that on my iPhone
I need to convert X lbs thrust on a day of Y temp and Z atmospheric pressure to X (corrected) lbs on a 59f (15c) day at 29.92", otherwise known as a 'standard day'.
This is how apples are compared to apples when testing in varying conditions which affect engine thrust.
Thx again tho,
Don.
Old 04-15-2011 | 08:14 PM
rcjetsaok's Avatar
My Feedback: (7)
You need a Density Altitude caculator... ???? I have one of those on a Jeppesen Flight calculator I have, but I'm not sure how you will corrolate thrust values... ??? I know what you are trying to do... I'm gonna have to backwards think on this !!!! I'll get back to you if I get a brainstorm... It seems if you know what the thrust value is at 29.92 , 59F at sea level, the you should be able to calculate precentage of performance lost due to Density Altitude increase, but converting that to lbs of thrust is what I'm not sure how to do... It's not going to be a linear scale I would think... All Performance charts I have seen and used have a curve that becomes more aggresive as the altitude increases... .... I think all the BS I have been saying is somewhat true... Keep me posted !!!!
Danno, Intrested and Confused !!!!
Old 04-15-2011 | 10:48 PM
highhorse's Avatar
LOL, that makes two of us. Ur onto exactly what i'm trying to figure out........
I may pm Oli from RCJI and ask him since they do this a lot.
Old 04-16-2011 | 05:10 AM
My Feedback: (106)
ORIGINAL: rcjetsaok
Danno
YepGreat little program. Have it and use it daily. Well worth the download.
Old 04-16-2011 | 05:13 AM
My simple setup
ID:	1594563   Click image for larger version
ORIGINAL: highhorse
I'd like to run some thrust tests on the bench, anyone have the hookup on a setup that's a bit more accurate than the ''Wal-Mart fish scale''?
Oli?
Thanks, Don.
Google "Force gauges" and you will find plenty of them.
Omega instruments makes a fine one.
Old 04-16-2011 | 05:36 AM
ORIGINAL: rcjetsaok
Danno
Sweet! What a useful program! [8D]
Shaz
Old 04-16-2011 | 05:49 AM
Don
http://www.scalesandbalances.co.uk/a...rce_Guage.html
I have an excellent Sauter gauge and a simple stand with a trolley that pushes against the gauge. The gauges measure in lbs Kg or Newtons.
Hope this helps.
John
Old 04-16-2011 | 05:53 AM
My Feedback: (49)
ORIGINAL: highhorse
Thanks, Don.
Google "engine correction factors", "dyno correction factors", or "SAE J1349". There are several websites that walk through the formulas and/or have programs to correct for air density. SAE J1349 is the standard used in the automotive industry to correct automotive engine horsepower and torque data to standard conditions. These same correction factors should also be applicable to turbine thrust.
Here's one I found that seems easy to use: http://www.csgnetwork.com/relhumhpcalc.html
There may be slightly different methodologies used in the aircraft industry, but this should work for your purpose.
Joe
Old 04-16-2011 | 08:12 AM
highhorse's Avatar
I had been playing the 'google game' before starting this thread but was asking the wrong questions, I think.
Thanks guys, I feel like Ive got some good starting points.
Old 04-16-2011 | 08:33 AM
highhorse's Avatar
Oops. Googling 'force guages', all I seem to find are units costing $600 and up !
