Futaba, or just 2.4, problems at Joe Nall?
#151
RE: Futaba, or just 2.4, problems at Joe Nall?
ORIGINAL: Doug Cronkhite
I'm really curious to see more on the new open-source 2.4g radio that was shown at the AMA show and Toledo recently, especially considering the price point.
#152
ORIGINAL: DougV
Nope, FASSTest is for the telemetry system (S.BUS II), including voice output: http://www.rc-network.de/forum/showthread.php/250150-FASSTEST-plus-bidirektionaler-S-BUS-II-(aus-futaba-forum.net)
Doug.
ORIGINAL: RC4LIFE
Noting http://www.futaba-rc.com/systems/18mz.html
Futaba now has ''FASSTestâ„¢ technology''
is there an implication that Futaba is tweaking their 2.4 FASST systems much like Spektrum did to address this issue?
Doug.
#154
My Feedback: (10)
It looks like S Bus is DESIGNED to use multiple receivers. The real question I have is how (and what) do the S Bus receiver communicate with each other, as opposed to how they drive the servos (still important mind you)
If the receivers form some sort of ad hoc network, then they can decide which of them is receiving the best RF signal and they both use that signal (sound familiar?)
Imagine, one RX in the tail driving 8 servos, another RX in the nose driving a different 8 servos. Meanwhile behind the scenes, the 2 receivers are comparing who has the best signal from the TX and sharing it with the other. The signals to the servos are unaffected, they still come from the receiver they are hooked to.
#155
I'm not sure these problems are about too many transmitters being on, unless you think three is a lot. At a local field while setting the needles on a new aircraft/engine combo (DA-60), cowl off and hatch off, the receiver totally locked out. Fromeco switch with dual power leads and a freshly charged battery. The receiver would only reboot when the power switch was cycled. At the same time my plane was going through this we heard,"I ain't got it". and a Moki 1.80 powered Extra pounded the ground. Both radio systems use frequency hopping protocol, but different manufacturers. Radio tests after the crash of the Extra revealed no problems and battery and switch tests showed no issues. Range tests on both systems would be considered extraordinary. Both systems were sent back for a check out and have been returned with "no problems found" My repair center replaced the receiver as a courtesy, but the other flyer's repair center replaced nothing. I tried a different transmitter in my plane with a different receiver and this combo locked out twice. I tested it again with another plane bound to the same transmitter sitting next to it and that plane did not lock-out, but the problem plane did. It locked out twice, but I have not been able to get it to lock out again. I installed my old 72 meg. system and tests were without problems so it was flown without incident. This seems to indicate that there is something in my plane that my 2.4 system doesn't like. But what about the crashed Extra. No ignition, and it had had over 50 flights without so much as a glitch. My system had problems in two other planes with lock outs that resulted in a crash, but I found what I though were battery/switch problems. Now I'm not so sure. At this same field we have lost maybe 6 or 8 planes with 2.4 in the last 18 months with some type of radio anomaly. Those planes were NOT using frequency hopping, but were on 2.4 The number of flights at our field on 2.4 without incident is by far the majority, but I can not help but wonder if there is more to the story than we know.
#156
NC
ORIGINAL: franklin_m
Regardless of whether it's DSSS or FHSS, there's only a finite number of frequencies and a finite number of coding sequences. Even if the number of coding sequences is large, at what point does the number of transmitters start to load up enough points in time to the point where a receiver locks out? How "random" are the random code generators? How long does the receiver processing take? I've seen any number of systems overloaded just by making a receiver spend too much time trying to sort out what's real and what's not.
Each system has a limited number of frequencies that they can transmit on. I believe thatDSM2 has 80 (40 pairs). As best as I can tell, FASST is limited to 36 (less if in "France" mode). There has to be a limit as to how many can be operating at once, before serious degradation in performance occurs.
It would be wise that anyone needing to turn on a transmitter to setup or checka plane do so in reduced power mode (like you would use for range checking). This would limit the possible negative affect on those that are flying. JMHO.
#157
FL
ORIGINAL: mr_matt
The way I see it and I can be wrong, when you use S.BUS, you program the servos to lets say elevator, so no matter where in the S.BUS chain you connect that servo, it’s going to be an elevator servo.
Doug.
#158
My Feedback: (106)
TN
ORIGINAL: DougV
So where's all these crashes apart from Shui's that's related to Futaba at the Nall?
Doug.
ORIGINAL: bevar
Well...I'd say last week at the 'Nall pretty much dispels that myth.
Beave
Beave
ORIGINAL: ira d
Spektrum / JR are the only ones using remote receivers yet all the systems that dont perform just as good if not better IMO.
Doug.
I was wondering the same thing!
#159
The only other I know for sure was Team Robart's P-47 that went into fail safe and hit the trees behind vendors row... I was standing very near where it went in. I've heard a few other stories but did not see it happen.
Steve
Steve
#160
FL
ORIGINAL: StevL
Steve
Steve
Doug.
#161
ORIGINAL: StevL
Steve
Steve
Hi,
Maybe the guy that keeps opportunistically hyping this Futaba hysteria can chime in with that information. To read his posts, you'd think every other Futaba-guided plane went in at the Nall....
#162
ORIGINAL: mr_matt
#164
Ok!! I know how much you old dudes hate change. but come on 72MHz over 2.4GHz. come on!!!! I bet your still using dry cell EverReady's to start your Hornet.
I'm flying with an Airtronics SD-10G channel 2.4GHz radio the latency is half that of most other name brand radios and after two years......... not one little burp!!!!!! I can't blame anything on the radio system. NOTHING. I had a battery problem once......I Should have had redundancy built in but didn't My BAD . Never a radio problem. I don't fly turbine But I do Scale, Giant scale, Gas, and glow 4cycle.
Don't listen to gossip. Do the research find the truth. 2.4 gigahertz = 2 400 megahertz a lot faster then 72MHz hah?
#165
Carbon fiber next to your 2.4 reciever antennas will cause interference with your reciever in my Futaba manual it says keep antennas away from carbon fiber at least 1/2 " away, also 90 degrees apart. Just my imput.
#171
My Feedback: (10)
IN
shovelrigid, I believe you will find that 2.4 is not faster than 72mhz. 2.4ghz and 72mhz is cycles per second and not speed.
I believe that all signals travel at the speed of light which is 186,000 miles per second.
#172
ORIGINAL: turkey hunter
LOL,
Kinda reminds me of Egypt culling all the pigs in response to the Swine Flu situation...
#173
#175
NC
ORIGINAL: bigbaggy
The response time is faster, more cycles per second to transmit the data. Faster updates ect.
