 JETCAT lipo balancing plug >
Old 06-15-2011 | 08:50 PM
Wayne22's Avatar
Default JETCAT lipo balancing plug
My P-80 came with a 2500 MaH 2 cell Lipo which has a weird plug on the balancing lead. I can't find any balancing harness or board that it will fit into.
Does anyone know what will work??
Old 06-15-2011 | 09:19 PM
FILE IFR 's Avatar
Default RE: JETCAT lipo balancing plug
I just plug an Astro Blinky Balancer into the port while charging through the main power leads.
Old 06-15-2011 | 10:29 PM
The type is called EH. Graupner chargers (and some others) have this is in the case and supply adaptor leads and boards for other types.
Dw
Old 06-16-2011 | 12:35 AM
BaldEagel's Avatar
ORIGINAL: Wayne22
If you have standadised on one particular balance lead just change the plugs to your preferred one, you will find that most plugs have the same sockets in them, push the tag down one at a time and change the socket into your preferred balance plug.
Mike
Old 06-16-2011 | 05:17 AM
Wayne, can you post a picture,
I had the same problem and found an adaptor lead.
I think I had to order 5 of them so I can send you one if its the same.
Old 06-16-2011 | 08:40 PM
Wayne22's Avatar
Thanks for all the help guys...I may be swapping it for a bigger pack anyways as I just found out that this pack can only do 2 or 3 kero starts between charges......
