servos/to much torque?????? >
Old 08-18-2003 | 08:22 PM
Default servos/to much torque??????
hi,
working on a set up for a sport jet and getting confused.
why can't i use high torque on all servos.?? is it not a good idea
to use a lot of torque, or more than is recomended? also can't i
use coreless,metal geared on all areas? seems like factory
recomendations are really close
as far as torque goes in many areas. How do they figure what
to put where>??????
thanx for any help you can offer, BILL
Old 08-18-2003 | 11:37 PM
My Feedback: (10)
Using a servo with stronger than minimum specified torque rating is not a problem unless the servo is a physically larger size.
There isnt any issue with using a stronger servo, if anything its less wear & tear on the servo & gears, and more insurance the control surface will be adequately powered.
AJC
Old 08-18-2003 | 11:49 PM
Only other issue is power. You will be using up your flight pack faster than necessary, but NiCads are cheap (but not fancy new batteries).
