bad landing
My Feedback: (32)
on touch down? Can also be a nose strut with a spring rate that is to "bouncy. I have flown a lot of planes with inconsistent approach due to dirty air and/or downwash over the tail. Very frustrating. A slight difference in speed can make a big difference in pitch force. I usually have to reduce flap angle. I haven't noticed any pattern relating to tail size.
Agree with Brad. I am not aware of anyone who makes noseleg struts, everyone uses a main leg strut with a spring rate and pre-tension suited to the weight put on a main leg. The result is a noseleg with a higher frequency than the main legs, often so hard as to have no give at all, and the result is a bouncing nose while the main legs are going downwards, which pitches the plane back up again. I have altered the springs in all of mine and it makes a difference.
ORIGINAL: rcpete347
HI all, how many would agree that a badly designed jet that porpoises on landing is caused by a scale tail ( too small, no 15% increase) or by the elevator getting blocked out.
Thanks in advance.
Rcpete
Thanks in advance.
Rcpete
Just sell that thing and stop beating around the bush, you know what to buy.
Chuck
My Feedback: (49)
ORIGINAL: rcpete347
Thanks in advance.
Rcpete
Thanks in advance.
Rcpete
David S
My Feedback: (251)
HI all, just to clear my question, the porpoise is in the air on final. When the best Pilot in the world has trouble landing a *#!*^ and he has to land on the low of the porpoise, I think their is a design problem or like David says, reduce the flaps.
I was also thinking, the flaps
Rcpete
PS. on the ground, it is called the Kangeroo Hop
Rcpete
FL
ORIGINAL: rcpete347
Thanks in advance.
Rcpete
Thanks in advance.
Rcpete
Pete:
If the jet porpoises in the air only on final near the pavement then it must be "ground effect" and some interaction with some airfoil (like flaps, etc. as others have suggested and maybe airspeed) . If flaps were the issue, I would think the only way to be sure would be to land with varying degree of flaps to see if that cures the problem.
Nick
Nick
