P-100RX....who's a lucky boy!
Xmas again! The PKZ Spitfires arrived and then Mr UPS with a P-100RX. The Global JetClub Mig15 was crying out for this engine, so I made a begging request to get a pre release unit as soon as JC had one, the Mig is due to be flown at JP and they have made it possible.
Unit comes with a 3s Li-Fe pack and bus fuel pump, single lead and tube connection should help with a super fast install.
Very happy Dave
Very happy Dave
RE: P-100RX....who's a lucky boy!
These damn things are like buses, You wait all year for one then 2 come at once...
I visited Al's Hobbies and Motors & Rotors today and both of them received P100's this morning. Now these guys are supposed to be model shops but neither would sell me theirs !! [:@]
Still I bet I'm the first person.......in the world...... to have seen two different P100's today Engine looks sweet - although the box looks a bit empty - small engine, no separate valves.
Would it be possible to bring one for me on Friday Al? It's for that customer build... It was all ordered ages ago but of course I don't know where he is on the list, but on the off chance I thought I'd ask
Short, stubby and light [:@]
and the turbine is just a tad over 1 kg 1.086 to be precise 2.39 lbs for our Canadian friends
25 cm long 10 cm diameter just under 10" by 4"
Regards Al
Regards Al
Those that haven't spotted it, the case has a machined ridge around the centre for the motor mount to locate in. With no external temp probe it is easy to install/remove.
Dw
Dw
We Need some videos of these little monsters running now![>:] Ali being you cant figure out a plane to put it in, a test bench video would be great.
[8D]
[8D]
I really like the design they are going with only one fuel like and its pretty cool how there smoke pump plugs into the fuel pump. Will all the jetcat turbines go to this design?
Test bench.... Whats a Test Bench? Is that like a model with no wings on it? My P100 goes into a plane tomorrow. Just two projects for jet power to get done tonight ( almost there ) and then its onto the P100.
Regards Al
Regards Al
nice! i have to agree with you on the test bench I'm currently running 2 jets cats and a 3rd one on the way P60SE and 2 p80SE and the P80 n P60 I'm running right now never went on the test bench, direct from their box to the airplane.
Kenrico,
I really dont know of any of the modern turbines that require running on a test bench any more. The JC's especially. Running them for the first time is such a non event that its literally just plug and play. Good luck with your third CAT. I am sure it will run just as the other two do.
Dennis.
Regards Al
Dennis.
Regards Al
I have a customer who ordered a P-100RX to go in a Bandit ARF, FYI the P-70 mount works wih just a tiny mod.
Also the stock mount provided is approx 130mm (5 3/16") across the mounting holes
Dave
Dave
