Yellow F22 Build
My Feedback: (287)
MA
RE: Yellow F22 Build
Ok John your killing me with that neat tidy install ! I am NEVER gonna take the canopy off mine when you are around! I really Love flying my yellow f-22. you are gonna have a great plane when you are done!
Later
Brian : )
Later
Brian : )
gunnradd
Further to my last email re thrust vectoring install
Not sure what the latest instructions say about the servos for the thrust vectoring, but if you can install them on the lower side of formers near the floor of the model and then linked to the bottom of the vector units. mine are on the topeach side of the thrust tube and hence why it is a pain to install, can be done but better and easier on the bottom
hope this helps
Ian
hope this helps
Ian
I have the Christian Diffusion F22 - great flying model! You'll love it! The speed envelope is fantastic - with 15kts or so, my jet will hover with about 20 alpha, and with the tap open it gets moving very nicely! One thing that I noticed about most model Raptors is that the pilots are too large! The Raptor is a huge aircraft - worth putting a smaller scale bust in the cockpit to get the look right! Enjoy the build and the flying.
Cheers - Pat
Cheers - Pat
My Feedback: (9)
Jon thanks for the pics! I know the plane is stealth but install pics have been stealth also lol.
Ian my thrust vectoring I got has the servo connections on the top. I didnt know that you could get them on the bottom. Yellow Aircraft is not making the thrust vectoring at this time and I was lucky to get what I got. Charles told me the guy that made them is not doing it anymore. So those of us that have it we are lucky!!!
I got the gear all painted white. And I am trying to run the engine today on the test bench.
Ok re vector servos at the top , It is just getting in there even with average size hands.
Once installed I have had no issues.
I did build a little lite ply shield painted with a couple of coats of heat shield between the servos and the pipe just to reduce chance of radiated heat.
As I said no problems in operation.
Pat B I do agree re pilot size I have "adjusted" mine since the photos I posted earlier
Ian
Ian
#32
GA
ORIGINAL: gunradd
#33
Gunradd, there is an very good and extensive thread on the F-22 that I used while building my plane. Look for "Yellow F-22 CG hinges pics". Good reference for paint color codes, gear door reinforcing, equipment installation etc. I'd put the link on this note but I'm not sure how to do that. Just copy "Yellow F-22 CG hinges pics" and paste it into the search engine block.
#36
GA
jkirkon,Thanks for the link.clguru really put up a really nice build thread(nice work).There were some photos of the vector exhaust I found interesting.looks like a well design and assembled unit.What the story on that? was it after market piece that is no longer available....or can you get it from Shawn or Charles.I beleive gunnradd said he got the last one.And if you have one does it just bolt in..just curious.
#37
My Feedback: (9)
It might be a temp problem at yellow. But charles said the guy that made the thrust vector kit is no longer with them. So at some point in time they will probably get them back. And yes its a very well made unit. Not sure how it attaches yet....... need the plane lol.
Update on the engine runs................... I have a bad ECU and a broken brush on the starter motor. So engine runs are set back a for a while.
#39
HI
The closest I've come to duplicating the F-22 paint is to mix the standard FS (dark and light grey) with silver. Use 5 parts silver to one part grey. It will look too bright until you shoot the semi-flat clear which really tones it down.
#40
Hi
Vector unit worksvery well and is first class, engineered and build.
The thrust vector unit attaches by four self tapping socket screws to the rear bulk head. screws are fed in between the outer scale petals and the inner thrust tubes.
The two units are actuated by heavy duty ball links from servos by metal push rods. To retrofit you do need the specific thrust tube thatfeeds the vector pipes which sit outside the main thrust tube.
Ian
Ian
#42
My Feedback: (15)
I am glad to see interest in this F22 again!
I am still flying my 2008 version which has no thrust vectoring. The only thing I have had to do to the plane is change the tires and replace/repair the main door hinge.
I would suggest to those building it to make the main gear door wood hinge mechanism removeable rather than glued in. I screwed mine in with a few reinforcements. it is simple and maintenance is easy this way.
Watch the nose gear mount, with the main gear so far back the nose doesnt touch lightly (no tlike an F15...)
I am not sure if I am envious of the thrust vectoring or glad I dont have the extra weight? I wont be changing mine.
Good luck to those who are getting into this plane, it is stable, fun, has a wide speed envelope and requires little maintenance and had great landing gear!
Dave
Dave
#43
Hi Tom
The photo was just for effect. I don't use anything like that movement.
yes I have programmed it for both elevator and roll, but todate have only used it in elevator. Was not aware the real 22 only used it it in pitch.
Dave thanks for the feedback, mine has had zero issues so far.
My main doors are removable.
any help I can provide to the others with their 22's let me know
Ian
Ian
#45
My Feedback: (28)
My main doors are removable also. I keep a set of spare hinges.....and need them evey now and than. I boofed the landing gear on mine the last time out and needs repair. I will move the CG back about 1" when I do the repairs. I really think we have it way too far forward at 6.5" I dont get the response from the VT as I would expect.
#46
My Feedback: (9)
Small update.
I got the new ECU from jet central and a new starter and the engine fired up right away. Made plenty of power and is ready to go!!
I hope to have the airframe in the next few weeks to get cranking on the build.
EDIT
Just called yellow and they wont have the airframes until the first of January. Not very excited to say the least. 3 month wait for a kit is a bit much. But still glad I didnt get the jetlegend F22. Yellow looks much more scale. So I guess I wait.
EDIT
#50
My Feedback: (9)
ORIGINAL: tp777fo
Trust me...it is well worth the wait!
Tom do you think one could build and fly the F22 in primer in a month and a half?? With the wings being glassed already what is the most time consuming part?
I am going to order some carbon fibre plates and make the trays for the engine componets and get all that done now that the engine is dialed in. Tom is the trays Shaun made for the F22 ARF the way to go for easy access? I think I will copy his but in carbon instead.
