Old 12-14-2011 | 07:40 AM
Default .
Old 12-14-2011 | 08:07 AM
MaJ. Woody's Avatar
My Feedback: (28)
Default RE: .
Yep. Look here..........
http://dreamworksrc.com/catalog/mach...rt-p-1426.html
Old 12-14-2011 | 08:08 AM
Default RE: .
Model Aviation Products make very nice rings that are perfect for the job. They fit through the hole and have a flange with lots of little holes drilled to hold the glue and set it securely. I am having some tanks made at the moment and am using the MAP rings on them. The FEJ tanks are not naff, they just need finishing off. I would never use a fibreglass tank without fitting an aluminium ring to strengthen it. As yours have cracks you will have to pray that the glue fills it and makes a waterproof joint. You may be able to seal any tiny cracks with Cyano after the ring is fitted. You can use Hysol or I have found Acrylic glue for this application to be better as it runs into cracks.
John
Old 12-14-2011 | 08:10 AM
Vincent's Avatar
My Feedback: (61)
Default RE: .
these would work.
Vin...
Old 12-14-2011 | 08:14 AM
Default RE: .
I just checked Ali stocks them
http://alshobbies.com/shop/cat.php?i...=21&NumShow=20
John
Old 12-14-2011 | 08:44 AM
FenderBean's Avatar
Default RE: .
yeah unless you get the kevlar versions any fuel tank should have the metal inserts. They all will crack over time, I dont plan on getting the tank upgrades on my next jets since I think the fiber glass will work just fine.
