 Do you or Dont You >
Do you or Dont You
View Poll Results: A poll
Yes
56.65%
No
43.35%
Voters: 173. You may not vote on this poll
Do you or Dont You
Old 12-31-2011 | 09:15 PM
Default RE: Do you or Dont You
suggestion for subject line: Poll ECU battery charging
Generally a good idea that the subject line gives people an idea of what the post is about so you don't waste the time of those to whom it does not apply.
invertmast's Avatar
My Feedback: (23)
A123's in all my jets.. and i'm slowly converting most of my electric fleet from Lipo's to A123's as well.
Old 01-01-2012 | 01:03 AM
Banned
ORIGINAL: MetallicaJunkie
ORIGINAL: ddlstang
Why did you ask the question if you are going to be sarcastic toward someone that is urging caution.
because he want to be a cyber-bully behind his KB
Slight over reaction I might suggest. Happy new year
Bod
Old 01-01-2012 | 07:08 AM
I have a 2 lipos in a TF Giant P-47. I charge them out of the plane in the house in a lipo sack in case they do catch fire. I also take them out of the plane when not in use. The problem is that there are 2 sides of the story with anything. Can they go up in flame just sitting there? Yes. Can they go up in flames when I charge them? Yes. Can I die walking across the street....Yes. I just take some precautions regardless by charging in the lipo sack and taking them out of the plane. Charging them outside is an idea too I never thought of, but the precautions we all are taking with the ammo box and outside just reduce the odds of something bad happen because that ammo box can still fail or something else can fail. It's just the odds of something happening are slimmer.
Old 01-01-2012 | 09:12 AM
BaldEagel's Avatar
If your turbine is Kero start the load on the battery means the likelyhood of a ballance issue arrising increase's therefore the need to ballance on charging also increase's, hence the increased usage of A123/LiFe's in jets.
Mike
Old 01-01-2012 | 10:12 AM
  #31
Xairflyer's Avatar
Mike how many cells are you using for the ECU with the A123's
Old 01-01-2012 | 11:52 AM
  #32
BaldEagel's Avatar
I use three A123 cells on both my converted JetCat ECU's both @ 2300Mah one converted by JC Germany and one by JC USA.
Mike
Old 01-01-2012 | 02:20 PM
  #33
dubd's Avatar
As they say, ignorance is bliss...
Old 01-01-2012 | 06:54 PM
  #34
Just curious are cell phones lipo or ion??
