 Pipe without Bellmouth? >
Old 02-09-2012 | 02:52 PM
Default Pipe without Bellmouth?
Hi guys, my Panther jet from feibao is almost done, but my pupe doesn't have a bellmouth... Can I run the engine like this? Is it possible? Or is it cath on fire?
If I can run, what's the gap that sould I leave?
Thanks guys, you're awsome!
Old 02-09-2012 | 03:09 PM
AndyAndrews's Avatar
Default RE: Pipe without Bellmouth?
I wouldn't run it without a bellmouth unless you are using a bypass. The distance required depends on your turbine manufacturer. It should be listed in your manual.
Old 02-09-2012 | 03:19 PM
ianober's Avatar
My Feedback: (12)
I am sure it came with a bypass. I am using that setup on my Hornet right now but not using the top cover, just the lower portion of the bypass.
