TurboProp Reliability
Guys,
For those running the latest Jetcat turboprops, how is reliability nowadays?
Despite the superb reliability of their regular turbines, I've witnessed these units failing far too often. I gambled on one and had it last 4 flights before it needed to go back. That was about 3 years ago.
I'm hoping that they've improved these alongside the regular turbines?
I can handle the hassle of sending it back for fixing etc, just not too keen on the (seemingly increased) risk of losing a model if it packs up in the wrong place.
Any input from anyone? Oh, and rather than start a brand war. I am only interested in using the JetCat unit thanks
Cheers,
Mark
Cheers,
Mark
RE: TurboProp Reliability
Marc,
I currently have a V2 SPT5-H in a heli with over 8 hours running time.
It runs between 145000 and 16500 most of the time and no issues with gearbox or anything.
It was updated last year to have one of the output drive wheel replaced as the original was within a problem number of being to thin and failing.
Other than that - a great engine.
modtron
Oxford UK
modtron
Oxford UK
Mark
All the Mk3 units are working 100%. It took a few years, but yes they are there now..
Colin has been flying a Tuc for over a year without an issue and I have other guys seeing the same reliability.
Dave
Dave
Mark,
New to the turbo prop thing as I only have 6 flights with mine, but the Mk3 is running like a Swiss clock. I also own a Spt5h since 2009 with absolutely no issues. Neither have had a flame out as yet.
Cheers,
Jan
Cheers,
Jan
My Feedback: (27)
Mark,
I made the 60th flight this afternoon with my Jetcat SPT5-V3. It has performed flawlessly (besides the time I ran it out of gas, but I suppose that was my fault...LOL) and I could not be happier with it. Perfect starts, tons of power (way more that the previous TP I had been flying in my Tucano) and dead solid reliability.
It's the class of the field IMO...you will love it.
Beave
Beave
Beave,
Are you using the standard tanks? If so, what have you set as a time limit on your flights? Currently I have 6.5 minutes and it seems rather conservative.
Cheers,
Jan
Cheers,
Jan
Beave, sounds to me that my timer may be even longer than yours. My timer is only activated once my throttle moves beyond idle. When do you start your timer? Cheers, Jan
I have a SPT5 -V3 that needed to go back after two 5min flights. The gearbox began to make a strange noise and grease was coming out of the big front bearing.
It is back at Jetcat for repair now....
There's been some problems reported with this turbine, but nothing as it used to be. Some people are limiting the RPM's and that seems to be a good solution since none of them have reported problems.
My Feedback: (84)
For slightly smaller planes.. you can't beat the WREN 44tp.. it will give you approx 36+ lbs static thrust and LOTSof fun!
hopefully they will re-introduce the 54TP sometime...
I never had a failure with this unit .. Iused DTE light@5%
SEE HERE>>> http://www.youtube.com/watch?v=2HBUTb4oyNI
http://www.youtube.com/watch?v=KBqBhwuE2M8
http://www.youtube.com/watch?v=On8cKUZ-2xY
http://www.youtube.com/watch?v=WwHYYth1YWU
PA
ORIGINAL: geh3
I wan't Jet cat to release a turbo prop based off of the P-20, so I can fly 120 sized models with it.
My Feedback: (27)
Guys,
Turbo props in general are going to be more delicate than a regular turbine or a gasser. The new V3 Jetcat is the cats meow (OK...that was a funny) as far I am concerned. I have over 200 logged TP flights so I am getting pretty used to what the deal is. Are they bullet proof? Oh boy...not by a mile. Are they pretty reliable now a days? Indeed...and getting better by the day.
When I first started flying my Tucano a little over two years ago...I was experiencing powerplant failures, some catastrophic every 5 to 6 flights. I was on my 7th powerplant before I was able to get beyond the 6 flight failure threshold. I worked closely with the manufacturer testing all kinds of things to see how to get the reliability up, including wrapping the engine and gearbox with an Eagletree System to log trends, temps, RPMs ETC to try to see what was going on. My 7th engine was a gem and after 50 some odd flights I sold it to a friend who got another 50 or so flights out of it before a bearing let go. No big deal...they fixed it and it's still going strong...in fact I flew it yesterday with him...as well as flying mine.
I have two friends who have/had identical planes and engines two years ago and they too experienced the "5 to 6 flights in between failures" drama. One friend after 4 failures, had to replace a wing and landing gear on his Tucano because of a dead stick and switched to the Jetcat V3 and has been trouble free for over a year. My other friend lost his Tucano from his final powerplant failure and is looking at the Jetcat for his next bird.
As I said before, both my surviving Tucano friend (highly respected in the Jet community, AMA leadership person ETC) and I both switched to Jetcat last year and have been beyond pleased. We have almost 100 total flights between us and have not have the first issue of any kind. Tremendous power (for a TP), awesome reliability ETC ETC ETC.
I have heard of a V3 or two having problems, but that's just the way it goes I suppose.. I have owned PST, Jet Central, Jetcat and EVO Jet engines and guess what...they have all had some kind of failures/issues of some sort. No...not everyone of them have failed, but what I am trying to say is that no one makes perfect products...sooner or later one of them is going to go kaboom.
Beave
Beave
Today my turboprop arrived back. It was last thursday that I had it shipped. Well done Jetcat!! [8D] It seems have a new gearbox (was broken), new fuelpump and I think also the ECU.
I'm curious if the problem is solved (remains solved )
My Feedback: (26)
I replaced my Wren 54 turboprop with a brand new JetCat V3 today. The gearbox in the Wren failed a couple of weeks ago so it's going back to the UK for repair.
What a difference in power... Wow. The tucano was a lame duck with the Wren with very limited vertical performance. First flight tomorrow, but spooled the V3 up in the backyard today. Incredibly smooth start and running. And I love the very silent cool down sequence.
My Feedback: (27)
Woohoo!! JC...let me know how it goes.
Still heading to Top Gun next week?
Beave
Beave
ORIGINAL: -JC-
My Feedback: (26)
Yes Beave, leaving Monday hoping to put a bunch of flight on the Tucano tomorrow and Sunday. Markham Park should be pretty empty with the Air & Sea show going on. The paint is still drying though and we still need to fit some scale details, but it will be ready. It took a little more work than expected to switch from Wren to JetCat. Some bodywork was needed.
My Feedback: (27)
Marvin,
We are using Biela 24/12 3 blade props on our Tucanos. I just received the new Biela 24/14 "Turbo Prop" propeller from Gerhard at AI. I have not tried it yet (I will after Top Gun) but it looks pretty sweet.
Beave
Beave
ORIGINAL: jonesmarvin
What size prop are you using ?
My Feedback: (27)
Joe,
Sounds sweet!!!
Beave
Sounds sweet!!!
Beave
ORIGINAL: Joe C
Hi Mark,
Ali is building me the new Comp-Arf SIAI Marchetti, I am sending him the new Jetcat turbo prop. Looking forward to something differant than the Tucano. Marchetti will be here for this year's Best In The West.
Hi Mark,
