Spektrum Telemetry TM1000
Hi
Has anybody tried the Spektrum TM1000 telemetry module with any of the Powerbox Cockpit or Royal series.
I just installed the TM1000 in my airplane but i had to connect the unit to the receiver and not thru the Powerbox.
The TM1000 comes with a standard 3 wire JR type cable to connect to the telemetry port , where as the Powerbox has a 4 pole wire with the white connector for Spektrum telemery.
If I use the Airspeed sensor there isnt another 4 pole port left on the TM1000.
RE: Spektrum Telemetry TM1000
hi I have a spektrum tm1000 wanting to connect it to a powerbox cockpit srs but i find it difficult to find a cable with a 3 plug spektrum one side(to fit in the data plug on the tm 1000) and a 4 terminal spektrum plug on the other side to fit the spektrum telemetyry plug on the powerbox cockpit srs) ,i can jion two cables together but i am not sure of wich wires to connect the one has four wires and other has three and they are both spectrim cables .if any one can give advice on this please
david
david
