Reload this Page >
JET LEGEND VIPER BUILD THREAD
Old 08-02-2015, 09:56 AM
  #1526
erwin peters
Hello, the aluminum Hitec servo arm 1” length would be ok to use in all surfaces?? I just order the plane and want to order servos.
Regards
Erwin
Old 08-03-2015, 05:45 PM
  #1527
M3Baker
M3Baker's Avatar
Yes, 1" arms all around on mine.
Old 08-03-2015, 07:10 PM
  #1528
gsmarino2000
I used the black HD arms ... mostly for looks (my plane is black underneath).
Greg
Old 08-05-2015, 03:09 PM
  #1529
barger
I hate to ask but whats the trick to getting air into the system.I have no air retract experience and i dont want to damage anything but i assume this is a oneway valve and i could use a common needle valve used for sports equipment.I have tried a hand pump and it does ot seem to want to take air.What am i missing here I could try something more powerful but i am afraid to damage something.
Old 08-05-2015, 03:21 PM
  #1530
barger
Also while i am at it bench ran the k100 and it runs beautiful,Installed today and have everything where i think i want it and it balances level UAT full main tank empty gear down....,picked up at front of hatch opening.Any thoughts on this balance point?
Old 08-05-2015, 03:36 PM
  #1531
M3Baker
M3Baker's Avatar
The front of the hatch opening is a pretty good balance point and will give you a slight nose heavy. This jet has a huge CG range.
On your prior question, use a bicycle needle to put air in. It is a check valve and only lets air go in. Around 110 PSI is all it needs if you don't have leaks.
Old 08-05-2015, 06:23 PM
  #1532
barger
Thanks i was able to get some air in it with my big shop compressor but only about 20 lbs by the gauge .Not sure whats going on i have everything hooked up no leaks that i can hear.Unless its squeezing back out around the needle and tube when i try to put it in.I seen guys use small compressors and i cant get air in with a big one.Could valve be no good it seems to resist air being forced in.It should be fairly easy to get air in early on .No?
Old 08-06-2015, 04:08 AM
  #1533
M3Baker
M3Baker's Avatar
You will need a high psi compressor. One of these works really well:
http://www.sears.com/craftsman-c3-19...1&blockType=G1
Takes a lot of psi to push air into the system.
Old 08-06-2015, 06:09 AM
  #1534
barger
Ok thanks for the help i have it working now i was not being aggressive enough about getting the air in also was leaking around the needle found one that is more snug and it airs up to 100 psi
Old 08-06-2015, 09:29 AM
  #1535
essyou35
Get a robart fill valve and use that. I've had many of these "one way" valves fail. The robart one has the same needle used in car tires and you can even replace it if needed.
Then put the fill valve in the jet and you can use your pump directly instead of a needed used for balls.
You can see mine next to my guage in the front.
Old 08-06-2015, 09:56 AM
  #1536
M3Baker
M3Baker's Avatar
I use the very same set up. Never failed me.
Old 08-06-2015, 10:06 AM
  #1537
barger
Looks like quite a few upgrades in there.. I am happy to get it working today tested brakes on the floor and they seem to work nicely.I will try the stock parts first and then probably upgrade over time just want to get this bird in the air before their is a chill in the air up here in Canada. Thank you for the help gentleman!
Old 08-06-2015, 03:05 PM
  #1538
M3Baker
M3Baker's Avatar
Put some carbon fiber in mine too, Joey.
Old 08-10-2015, 02:47 PM
  #1539
barger
I am using the ar12120 with two 3300mah 2s li-po.The stock smoke pumps works fine when plugged into the ar12120 on a spare channel.The thing is i would like to use a external 2200 2s li-po for the the smoke pump because i am not crazy about using the rx batts for a smoke pump.I took the two power wires leading to the pump and soldered them to the external batt and left the signal wire plugged into the rx and the pump does not turn on?? any thoughts or opinions??Also any idea how many mah it might draw from the pack on one flight if i just go with using the rx packs?
Old 08-10-2015, 03:37 PM
  #1540
M3Baker
M3Baker's Avatar
That pump won't use much power. The JL pump is designed to run straight through the receiver. With 6600mAh you should be fine. While I don't have the smoke in my jet, I have a friend who does and he gets 4 or 5 flights between charges running a 6600mAh LiFe setup.
Old 08-10-2015, 04:05 PM
  #1541
barger
Your right they don't use much power i read they could run for a half hour straight and use less than 500mah. I will go ahead and use it as intended...Thank you again
Old 08-12-2015, 05:21 PM
  #1542
barger
What kind of flight times are you guys running the k100 getting... Its has the new single big tank but seems to be the same size as the original two tank set up.Just wondering what i should set my timer for the maiden.
Old 08-12-2015, 06:15 PM
  #1543
M3Baker
M3Baker's Avatar
I'm running a Rabbit SP which has a fuel consumption of 12.2oz per minute. I think the k100 is around 12. I'm getting a solid 8min flight with almost a quarter tank in reserve after landing.
Old 08-12-2015, 06:57 PM
  #1544
gsmarino2000
I have a K100G, but I am using the three-tank set up (two 900ml saddle tanks and one 1500 ml tank for a total of 3.3 liters). I started with 5 minutes for my maiden, but now I have my timer set to 6.5 minutes which is enough for me. I use about 1.8 liters (i.e. most of the saddle tanks but the front tank is still full). So around 280 ml/minute of actual flight time. That is a lot better than the published 350g (428ml) /minute, but I typically fly around at half throttle and use full throttle at take off and during vertical climbs. I could safely hit 9 or 10 minutes if I wanted to.
If yours tank is 3 liters, you could probably start with your timer at 6 or 7 minutes and adjust after the first flight or two. But I'd suggest measuring the volume first.
Greg
Old 08-12-2015, 08:51 PM
  #1545
Jason R.
Jason R.'s Avatar
Hi Barger, I also am running a K100G and have the 2 x 1500ml tanks and a 600ml rear tank. I have timer set on 8.5 mins and start timer on take off roll and do wheels down gear pass on the final countdown. Most of the time landing with about 800ml of fuel onboard.
Old 08-13-2015, 03:53 AM
  #1546
barger
Thanks fellas I think i will start with 6.5 then work my way up from there.Probably half throttle most of flight depending how comfortable i feel.Must be awsome to get 8+min .I am used to 4min with jtm viper ...just start to have fun and its time to come in.
Old 08-13-2015, 05:36 PM
  #1547
essyou35
I have no idea what you guys are doing. With my k100g I could fly 5 min MAX and the tanks were pretty empty. I fly 3/4 as 1/2 throttle I was get passed by the J3 Cubs
Old 08-14-2015, 02:21 AM
  #1548
extra300s
My viper also only uses 2L for 6.5min of good flying - half to 3/4 and full open on the climbs and loops. And do about 4 high speed low passes also. K100 installed.
Old 08-14-2015, 09:07 AM
  #1549
mikedenilin
My Feedback: (67)
My typical flying time is 7:30 and got about 1/3 tank left on one tank. I fly with a T12 turbine. Unfortunately, I ended it earlier when I had a mid-air with another Viper. It's such as great flyer, we both are going to get another vipers. Mike
Old 08-14-2015, 09:31 AM
  #1550
FenderBean
FenderBean's Avatar
Mike that's on par with Jose and Pauls, that's a really good flying time. I'm hoping the new project will have the same flight time.
