jmp vs os pipe >
jmp vs os pipe
jmp vs os pipe
Old 09-03-2003 | 01:31 PM
Default jmp vs os pipe
Just getting into ducted fans. What is the difference in pipes with the os 91?
I see the jmp pipe is 150$, the os pipe is 50$(plus 29$ for the header). Is there a significant difference???
Thank you
Old 09-03-2003 | 02:07 PM
grbaker's Avatar
My Feedback: (29)
Default Tuned pipes
You're best bet is to go with the JMP System II pipe. I know of no one that is using a OS pipe on a .91 VRDF. You can also run a BVM pipe.
Old 09-03-2003 | 10:31 PM
I have a system II pipe and was wondering if I can put a pressure tap in it. If so should I use large dia. tubing for pressure. Or should I just stick to pitot pressure, this is an OS 91 and Ramtec setup. Thank you
