 How often do you change your Socks... UAT socks that is... >
Old 07-06-2012 | 03:06 PM
invertmast's Avatar
My Feedback: (23)
Default How often do you change your Socks... UAT socks that is...
Like the title says.
How often do you guys replace your UAT filter socks?
Old 07-06-2012 | 03:11 PM
siddus74's Avatar
Default RE: How often do you change your Socks... UAT socks that is...
Your joking right? never?
Scott.
Old 07-06-2012 | 03:21 PM
rcpete347's Avatar
My Feedback: (251)
Never.
Rcpete
Old 07-06-2012 | 03:25 PM
invertmast's Avatar
My Feedback: (23)
Well, with everyone always talking about clunk or fuel line replacement, it seems prudent to replace the sock at some time... I guess i'll just save myself some stinky mess
Old 07-06-2012 | 04:14 PM
Guest
My Feedback: (73)
The only time I would change the sock would be if there was excessive algae on the bag, or it appeared very darkened and dirty. If the later is the reason, I would look to improve filtration on the fueling station as nothing should really even be getting into the fuel supply to begin with.
~V~
Old 07-07-2012 | 03:09 AM
Pat Barnes's Avatar
Never for me too! I've replaced the outer bottle on one sock - bottle was ruptured in a crash, nothing wrong with the innards - so £5 spent on new bottle saves £60 for new UAT! I also only put mil spec fuel in my jets as it has a fungus suppressant, so there is no fungus anywhere in my fuel systems.
Old 07-07-2012 | 04:11 AM
RCISFUN's Avatar
My Feedback: (44)
These are the exact same fuel pick up sock that is in automotive fuel tanks, the only time they get changed is if the fuel pump / sending unit needs replacement.
Old 07-07-2012 | 09:54 AM
Thud_Driver's Avatar
Airtex (& others) FS3 Fuel Strainer for $6 & up at your local auto parts store - OReilly's, Auto Zone, Pep Boys, etc.  You'll have to cut off the end with the metal fitting.  Been awhile, but I think you also have to cut the plastic thingy inside too.
Old 07-07-2012 | 10:48 AM
invertmast's Avatar
My Feedback: (23)
ORIGINAL: RCISFUN
Now that you mention it, i never really looked at it that way, but you are right..
Old 07-07-2012 | 11:03 AM
GSR
My Feedback: (145)
What Woj said. Scotty
Old 07-07-2012 | 11:46 AM
My Bobcat XL is over 10 years old and has over 1300 flights on it. Still using the same UAT that I installed when I first built it.
