Duralite ECU pack solved RAM Engine Problems! >
Old 09-04-2003 | 02:51 PM
lov2flyrc's Avatar
My Feedback: (24)
Default Duralite ECU pack solved RAM Engine Problems!
A buddy was having some engine problems with his Ram 750, if he had a failed start and restarted the engine without charging the ECU pack his engine would fluctuate RPMs at idle, usually idling around 50-55,000 rpm and would not drop any lower. We decided to try a Duralite Plus ECU pack and not only has this eliminated all the odd engine surges he was experiencing but he can now fly 7 to 10 flights without having to recharge. Just thought I would share....
Todd
Old 09-04-2003 | 04:17 PM
Don Perry's Avatar
My Feedback: (51)
Default Duralite
I am using the duralites in my Vario Jetcopter on the ECU and for RX & TX.
I too can at a min 8 Flights with mine and that is using a jetcat.
Nice not to have to bring all of your charging stuff for a day of flying!
Don
www.rnlinc.com
Old 09-09-2003 | 11:11 PM
1Eye's Avatar
Default RE: Duralite ECU pack solved RAM Engine Problems!
Todd wrote...
I'm about ready to go with Li-Ion packs for my ECUs also - if for no other reason than the number of flights per charge. I assume you used a 7.4V pack but what capacity? Are you guys going to step up for the Li-Ion setup (w/regulator) for the receiver/flight pack?
Mike
(oops - posted this before I saw the Ya or Na related post ... oh well)
Old 09-10-2003 | 08:20 AM
lov2flyrc's Avatar
My Feedback: (24)
Mike,
I've just started to use the Duralites on my receiver packs, i've been using them on the ECU for about 6 months now. I'm using their 2800ma pack on a 5.2 volt regulator for the receiver and a 3600ma for the ECU. Gotta love the flight times without a charge....
brg,
Todd
