Redundant RX packs are they overkill?
RE: Redundant RX packs are they overkill?
FWIW, I think you are far more likely to have a wiring/switch failure than a battery failure itself.. but no way to predict when something like a connector or switch fails.. Example...
I have twin Lion's on a wolverine with twin regs in a Jet.. we go fly... land, only one light is on on the switch...hmmmmm... No power on one pack... 0 Volts..... Na.... the weld came loose on the battery, but was making intermittent contact until it bounced around on the ground... jet flew fine on one 2600 Lion.. That intermittent contact would have been a total loss w one pack..
My Feedback: (22)
Why not 2x 1100mAh A123 instead of the bigger cells?
Yep I'm liking that idea... I'm running 2100 life packs now in my large planes. But use a single 1100 life in my Comp Arf Spark.
I checked and two 1100's with save me 4 oz over two 2100's.... that's pretty good.
Would you guys feel safe with two 1100 in a plane as big as the yellow twin F-18? or giant scale warbirds?
Should be fine I don't see an issue
#31
ORIGINAL: Ron101
Redundancy increases reliability only if you can fly with only one battery. I think that 1100 is too little of a yellow F18. Let's say a battery fails after 3 flights, then you are flying with a battery that only has around 600 mah left. Very little I would say. So I completely disagree with the principle of using two small batts instead of one.
I lost my L39 like that. Had 2 batteries, both 1800 mah. theoretically enough for about 6-8 flights. On flight 7, one batt failed (I think i only turned on one... ). when I dropped the flaps for landing, the good battery didnt have enough juice and the plane crashed. What should I have done differently? assume that I had only 1800mah and fly only 4 times. Or, if I want to fly 8 times between flights, put 2x3600mah's batteries
So, the way to do redundancy is: choose the one battery you would use, and put another one of equal power. And fly the number of flights that one would give you. Don't add the 2 (at the most, multiply by 1.5, but not 2)
It is like twin engine aircraft where the plane can't fly with just one (like seneca's and the like).... what was the point of making it twin? just added complexity, doubling the chance of failure
Hope this helps
Jack
#32
My Feedback: (32)
Ron, just my opinion. If adding a second pack makes you feel comfortable, then by all means do that. I agree with Jack, don't decrease the mAh because of weight. An additional 5 oz on that airframe is nothing. If the fans won't be enough power due to 5 oz added, then put fans in it that can handle the additional weight.
Kirk
Kirk
#33
My Feedback: (9)
I put in 2 packs and 2 switches.
With the 2 switches I turn one on test all controls then turn it off and turn battery 2 on and test all controls then go to both batteries for flight. This tests the switches and the batteries before each flight.
Not using switches is ok but its not practical if you want to test each bettery by itself before each flight with out fiddiling with the connectors.
#34
My Feedback: (10)
You should size the battery for redundancy. A 1100 mah pack plus the backup. Decide your safety margin with the one pack, charge every flight or 2. You are charging the flight batts anyway. And for a turbine you could top off the 1100 faster than you could pump the kero back in!
#35
My Feedback: (22)
All good points guys
I think I'll drop to two 1100's and top off every two flights.... this way I have the lightest setup and I can check battery health on the charger which is the best way with life packs
you can't test the voltage on life packs, they have a flat discharge cruve until the they drop off like a rock. You must charge and see what you put back for saftey. I know there are a few tester on the market that say they can test life, but I wouldn't trust them knowing what a life discharge curve looks like.
Have seen several big planes go in now because guys thought the could test the voltage on a life pack, you can't they hold voltage until they don't
#36
ORIGINAL: Ron101
Sorry, but I don't think that is a good set up. A larg F18 can be drawing around 500mah per flight. So imagine you do one flight. you have 750 left in each bat. Next flight, you forget to turn one on (i know, it wont happen, but lets say it does... a wire breaks, anything). you are going to fly a 500mah flight with 750 in your battery. Likelihood of crashing towards the end of the flight: High
Don't skimp on capacity, not worth it. It is the only thing you cant run off. You can deadstick land, but you can't run out of voltage. It is a mistake..
Your plane though...
Been bitten by this enought times already
PS: Plus, who wants to top off every other flight? I say drop a couple 5000mahs and forget about charging the whole weekend Flying these things is hard enough, don't add more variables that mess up with your brain.
#38
I run two 2200 ions in my F-16 plenty of flights
ORIGINAL: Ron101
I can run the dual 2100 in the F-18 whenever it's done...lol
this is for all my planes, so I want to try the dual 1100's in my warbirds, 3d and jet legend hawk
#39
ORIGINAL: Ron101
Still, I run 2x2600 on my Electra which uses less than 200mah per flight. But I guess after 3 planes down due to power system failures, you become a little paranoid
Hey, when are we flying together? too much internet talk, not enough airtime
Let me know when are you going out with Eric and I'll join you
Later
Jack
#40
My Feedback: (22)
sounds like fun Jack.... you should hit up oakdale with us...
we flew at livermore on Satuday, really nice weather
This weekend looks like it's going to be a hot mother.... but I'll let you know that next time we go out
I want to check out your electra, I might buy and electra kit to build after my F-18 not the arf.... hoping to find one that someone got burnt out trying to build
Thanks for the help and I know what your saying about better safe than sorry
later bud
Ron
later bud
Ron
#41
My Feedback: (39)
The current output of the A123 - 1100's is impressive. Also with 2 packs you have 2200 of capacity feeding the airframe with way more punch than nickel metals. I can remember lots of guys being happy with a couple of 600 mah nicad packs even on giant scale stuff. Granted, servo torque and current draw has really increased ESP with digitals.
I have also been running a wolverine switch with a cricket. Great combination.
PaulD
PaulD
#43
ORIGINAL: FenderBean
I run two 2200 ions in my F-16 plenty of flights.
#45
ORIGINAL: dubd
Discharge rate on 2200 ions is pretty low. 5200 or bust for me.
#47
ORIGINAL: highhorse
Discharge rate is low compared to...what? The draw spike is hardly more than a few amps, topping out at a 2 or 3c rate, right? I guess I don't get this one, but am wiling to learn if I'm missing something here.
ORIGINAL: dubd
#48
Don't forget CG.
Had a member at our club that thought he saved 5 oz by going with smaller batteries. But then added 5oz of lead right next to the battery to get the CG back.
When I need nose weight I just keep trying bigger batteries till it balances. If I have to carry the weight anyhow, I want it useful weight.
#49
ORIGINAL: flyinfool1
Don't forget CG.
Don't forget CG.
#50
Discharge rate for a 2600 mah ion is low compared to almost all other batteries, including 5200mah ion packs. The max discharge for 2600 ions is 4 amps. That isn't a problem under normal circumstances, but can be catostrophic if a servo stalls. A stalled servo can pull more than the 2600 mah ion can deliver. A 5200 mah ion can deliver 8 amps, which is why I have no issue using them. My rationale is rooted in my IMAC days where 2600 mah ions were frowned upon for anything above a 50cc plane.
Flight weight: 3.9oz (110 grams)
Size: 2.75 x 1.5 x .75in (7 x 3.8 x 2cm)
Discharge Amperage: 5.2Amp (2C)
Charge Rate: 1Amp
I'm not saying you don't have a point worth considering. But you are short on the lion amps and assuming a double failure, ie a stalled servo when a pack fails. I'm sure the lion can surge at well over the rated 5.2 amps as well......
