Flaps
I'm finishing a PST Reaction, with all Hitec servos, 123 batt. Specktrum 12020 reciever.
I'm using Hitecs 5685MH for flaps, BUT, twice they have freezed after approx. 5 -8 minutes turned on.
The first ones were sent to Hitec , and they told me the motor was burned ????
Any ideas, or suggestions?
Thanks;
ENT
Thanks;
ENT
My Feedback: (135)
MA
If you are trying to push the flaps beyond what the hinges will allow then you are straining the servo. When you are setting them up restrict the travel to some small amount using End Points then gradually increase the travel until you get to the mechanical limit or to the position you want. The way a servo works is it keeps trying to get to the commanded position. It does this by increasing the current going to the motor to try to get it to move. Eventually, the servo gets to the point that it cannot take any more current and the motor burns out.
PA
I gave up on Hitech after I lost a 3rd heli from a failed servo.
But regardless.... the above advice is good. Get a meter, and check the draw. You don't want a bind. A current draw could cause a brown-out (reset) on 2.4.
My Feedback: (7)
The HS 985s gives you a bit more at 6.0 v ( 172 oz. ) but also cost about two times more then the HS 645s [:@]
http://www.hitecrcd.com/products/ana.../hs-985mg.html
<span style="font-family: Arial; font-size: small; ">Hi,</span><div><font face="Arial" size="2">I have put together numerous planes all with Hitec servos except for one prop plane. All my Jets have digital servos, and Hitec with the exception of my SM Mig 29 which also have some JR servos.</font></div><div><font face="Arial" size="2">Always run Life Batteries 6.6 volt.I havenever run a voltage reducer, andnever had a problem. The only time I run a reducer is for my ignition on my gas motors.</font>
Ivan</div>
Ivan</div>
My Feedback: (17)
MS
Flaps are designed to change the airfoil curvefor increased lift on takeoff and landings, not to be air brakes like on a jet.Using anymore than the recommended settings just changes their function from creating lift to creating drag.
The flaps have good downward movement, but they have limit upward from top of the wing.
The wing skin is the hinge. Four servos burned, even with limited movement.
ENT
ENT
I suspect your voltage is too high for the servos used. I manfactured model servos for 16 yrs (1969-1985) and if any one ran more voltage than specified all warrantees were voided. I recently contacted Hitec about running their servos on 7.2V (2 A123 in series) and got vauge answer. They stated you could run their standard servos on 7.2 but I didn't find out which ones are standard. Personnally I won't run any servo above the specified voltage.
I've used Hitec 56xx series servos in prop warbirds and for the throttle on giant gas planes and have had a number of them burn out. I wouldn't use them for anything other than a 60 size prop job. The only servos from Hitec that have been trouble free for me are the 7955 and up series...
