Reload this Page >
Making an Ultra Flash into an F-20UF
Old 10-09-2012, 07:55 AM
Pinnacle Aviation
Pinnacle Aviation's Avatar
Default RE: Making an Ultra Flash into an F-20UF
Here is a bit of a tease for you all
Old 10-09-2012, 08:12 AM
basimpsn
Wow
Old 10-09-2012, 08:14 AM
Pinnacle Aviation
Some more during the final painting
Old 10-09-2012, 08:54 AM
Pinnacle Aviation
Some more photos, it looks a bit strange in gloss but that is for the weathering and decals, she will be clear coated 15% satin
Old 10-09-2012, 10:34 AM
Dave Wilshere
You must get board of producing things like this
Dw
Old 10-09-2012, 12:18 PM
  #31
Pinnacle Aviation
Never Dave, this is why I am full time now, every model is different.
Old 10-09-2012, 12:36 PM
  #32
k12rc
k12rc's Avatar
You make it look easy and i know the hours it takes to do it great looking plane
Old 10-09-2012, 01:05 PM
  #33
ollie witt
ollie witt's Avatar
Phil what are you doing to me! An Ultra Flash made to look like an F5... too good!
Old 10-09-2012, 01:23 PM
  #34
Eddie P
Eddie P's Avatar
WHOOOAAAHH!!! I like! Well done!
What type of paint are you using (sorry of mentioned earlier). I see the "auto door jamb" tape (dart tape or similar) is being used to good effect. Isn't it amazing how expensive that stuff is? (at least it is where I live but it's the only way to make nice transitions in camo schemes IMHO).
Your airframe choice, color and pattern choice are fantastically optimized for maximum bling and I suspect really decent visibility too for an F-20 based camo sport aircraft
Old 10-09-2012, 03:43 PM
  #35
InboundLZ
My Feedback: (10)
InboundLZ's Avatar
Very VERY nice work! I have a T-birds flash that has 380 flights on it now, I am thinking that when I hit 500 (or maybe even 400) I may have to give her a extream makeover! I love what you have done here and you give a guy a bunch to think about.
Again, nice work....maybe I should send you mine....
Old 10-10-2012, 02:29 AM
  #36
siclick33
Phil,
What is the masking tape that you use on the edges of the camouflage colours? I've seen it before but can't remember what it is or where you get it from.
Old 10-10-2012, 03:29 AM
  #37
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
ORIGINAL: siclick33
Phil,
Looks like 3-M foam tape Big $$$$$
http://www.youtube.com/watch?v=a27wvFNIL-U
Phil very nice job...well done!
Old 10-10-2012, 03:45 AM
  #38
Pinnacle Aviation
Hi guys, rather than explain here is a photo of the masking foam.
It's not that expensive about £18 per box and you get 50m in a box
  #39
Dr Honda
Dr Honda's Avatar
How do you darken the rivets and panel lines?
BTW... Very nice work.
Old 10-10-2012, 04:39 AM
  #40
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
List price in the states is $87.00 [X(] discounted it is $44.00
However that being said it does a fantastic job of creating a very good transition between paints, perfect for camo paint jobs.
http://www.tooltopia.com/3m-automoti...FZGiPAodBD8Aqg
Old 10-10-2012, 05:13 AM
  #41
Pinnacle Aviation
Hi tony,
I use artist oil paints for the weathering
Old 10-10-2012, 05:52 AM
  #42
Dr Honda
Dr Honda's Avatar
ORIGINAL: Pinnacle Aviation
Hi tony,
Thanks for the info... but how?? I'm sure you aren't brushing it into each and every rivet. Are you just wiping it in and out of the voids?
Old 10-10-2012, 06:05 AM
  #43
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
ORIGINAL: Dr Honda
Hi tony,
Tony look at post #376 which shows the soft edge 3m tape, Post #405, #406, #431 & #445 of the following thread shows how to weather, keep going in the thread and you will see water slide decal application
http://www.rcuniverse.com/forum/m_70...16/key_/tm.htm
Old 10-10-2012, 06:13 AM
  #44
smchale
My Feedback: (67)
smchale's Avatar
Here is another good link: http://www.rcuniverse.com/forum/m_10...m.htm#10921173
Rich,
I view the 3M foam tape as actually quite a bargain. It costs about 30cents a foot and is really effective for spraying a soft edge. I picked up a box a few years ago thinking it would be a lifetime supply. Well, quite a few models later I'm about to start my second life. . I can't recommend it enough.
Old 10-10-2012, 06:29 AM
  #45
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Sean
This is what is so great about RCU, so much exchange of knowledge.
Your right another great thread!
Old 10-10-2012, 06:39 AM
  #46
Dr Honda
Dr Honda's Avatar
thanks for the links.
Old 10-10-2012, 06:50 AM
  #47
Pinnacle Aviation
Hi guys, here are some shots of the weathering going on the underside of the wings. I apply the artist oil paints with a cloth then wipes it off with another cloth (not a tissue). This removes any unwanted paint from the surface and leaves the paint in the rivets and panel lines.
Old 10-10-2012, 06:54 AM
  #48
vease
vease's Avatar
Hi Phil
Cracking work as always.
One question. Do you apply the oils directly over the paint or have you put a seal on first?
Old 10-10-2012, 07:14 AM
  #49
Maestri-M
My Feedback: (43)
Where do you get the stripes??
Old 10-10-2012, 07:44 AM
  #50
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
That seems much simpler and faster than spraying with an airbrush then sanding with 1000 grit, then using 70% rubbing alcohol as Maj. Woody did on his weathering job, THANKS for sharing your techniques,
