Looking for Instructions for BVM Smooth Stop
My Feedback: (114)
Hi All,
Wondering if anyone has instructions for the BVM Smooth Stop pictured below...not sure which version it is. I have 2 versions of installation instructions but neither look like the one I have pictured below...
Thanks...
Thanks...
My Feedback: (29)
Actually that is a version 2 which has had the ball link removed and replaced with a pushrod, version 1 had a pushrod that did go inside the center of the cylinder, this one does not. the instructions should be basically the same, the only difference between versions is the actuating plunger, where in ver 2, the plunger is a solid brass bar and uses a ball link, this was to eliminate side loads exherted by the ver 1 pushrod.
