Xicoy brake and dual action valves????
#51
My Feedback: (7)
From what you said it sounds like you have it on a 2 position switch which wouldn't give you proportional braking anyways so I'd suggest you turn proportional mode off in the brake valve. If you have it on a slider and are simply moving it to full on and full off and it is still pulsing at full on then you need to repeat the setup procedure or something..
#52
I have mine configured for pulsed operation on my 14SG, I found that with 1 small (Robart) air tank I only had enough air for one landing roll-out and would be out of air by the time I taxied back to the pits. I added a 2nd small air tank and now have enough air for a few actuations. I have my brakes on a slider/lever, my technique is after touchdown I give about 3 quick cycles from off to about 3/4 of full on, this is all pulsed mode operation so I loose quite a bit of air, then I do a relatively slow cycle (about a second and a half maybe) from off to full on to come to a stop, then one last cycle of off to full on to stop in the pits. I start a flight with my brake tanks at about 100 psi, and after this routine I usually end up around 40 psi. I did stop using pulsed mode while I was waiting for a 2nd air tank but I found it was too easy to lock up the brakes.
#54
Hi guys
I have two of those valves installed in my Xcalibur , the gear cycling works great , but with the sigle action valve I only get the brakes to lock up , even though I have greased the discs ,and whe I tried the pulsed mode they empty the air tank in just one flight .
Has anyone tried using a robart air restrictor in the brake feed line? , I used 2 of those to slow the gears down , so I guess it might work with the brakes as well????
#55
Not sure about brake design in Xcalibur but I assume it to be traditional rubber O-ring against aluminium wheel hub. They do need grease once in say 20 landings... And often they are still too aggressive to be used with normal landing gear pressure. Pulsating linear operation does consume air... no doubt about that.
But I'm pretty sure that restrictor doesn't work on brakes. There is not much air flow just pressure to work with. Limiting servo travel for brake valve might work.
Because of that I have two systems on my Hawk 3bar / ½liter bottle and pulsating single valve for brakes and 6bar/1 liter for retracts and doors.
/Jyri
/Jyri
#57
Think of dual action like a two channel valve - gear up/gear down, doors open/doors closed, speed brake open/speed brake closed. Where as a single action would be for something like wheel brakes, where it’s just on or not on.
#58
I've always used mechanical valves like U.P.-3's. How do you time the cycle with a Xicoy? Delays and sequence timing?
#59
My Feedback: (54)
Has anyone had valve leaking problems? I have had three new ones leak in the last 3 years. Gasper claims that it is the system, but it isn't, due to replacing the valve with another same valve and the leaking issue goes away. Bohetec retracts don't leak and are better quality then this valve. Gasper claims my system leaks. I tested the whole system, but when the system is electronically powered and not cycling, the valve leaks with a soap test. Bubbles come out around the push buttons. Only way for it to get there, it to come up from the electronic part of the valve. I took one of them apart to see that it is leaking at where the square rubber seals meet the aluminum manifold. The surface is rough. Brought this to Gasper's attention, he blames my system. Yet, as I have said, I replaced it with another one of his valves, and the leak goes away. Sent one back to Dreamworks, who forwarded it onto Gasper more then 6 months ago. Not a word. Gasper told me that if I had to use retracts that needed a 100 psi, the standard pressure to fill to, that I shouldn't use his valves. Right now, I am done with his products. Engines included.
#63
Hi,
I do have this V2 valve in my FW 190 and would like to havce retract pressurized so the landing gear don`t collapse when powering off. Is it possible and how to program?
#64
My Feedback: (53)
What gear brand you have?
Normally once the gear is down and lock you no longer need air pressure....same applied for the up position.
Nut if the bear collapse that would mean to me it’s either not going to the locking position or doesn’t it have a lock position which would be strange, since event the low price one does...
#65
I hope someone can do a video on how to programme the Xicoy V1s for brakes, on a 3 position sw, so that it is OFF at Pos 1, FULL ON with sw in the centre/ Posn 2, and PULSED with sw at 3rd position or Posn 3.
I am not able to figure it out.
#66
I an also using the Xicoy Double Valve system for main gear, Works perfect.
So then i programmed it for proportional/ pules mode,
This almost completely empties the entire pressure in the tanks with one cycle of gear.
So i then reprogrammed the gear for normal operation.
I am sure the same thing will happen for the brakes if programmed for pulsed mode.
in which case it will reed a separate tank for brakes and possible with a good capacity also.
