 Kingtech 180G >
Kingtech 180G
Kingtech 180G
Old 01-20-2013 | 08:47 PM
757Driver's Avatar
My Feedback: (90)
Default Kingtech 180G
I like it!
http://www.youtube.com/watch?v=eiz2L...ature=youtu.be
Old 01-21-2013 | 04:38 AM
Default RE: Kingtech 180G
The first time I saw the K-170 on a test-stand putting out more than 36# even more than my Rhino 32# I was hooked .
http://www.youtube.com/watch?v=3RAjRfwJVuw
Old 01-21-2013 | 08:46 AM
FenderBean's Avatar
I really like my 170, I am planning to run 180s in both my twins. The 140/170/180 are all the same diameter so more power for same size mount
Old 01-21-2013 | 09:03 AM
ORIGINAL: FenderBean
I still don't know how Kingtech do it..but the scale don't lie lol
Old 01-21-2013 | 10:04 AM
757Driver's Avatar
My Feedback: (90)
The 180G will have a wide range of uses, especially if thrust is limited in smaller frames.
Old 01-21-2013 | 11:47 AM
marquisvns's Avatar
Thanks guys! Jason, Wen-Fu from the factory noticed that you have the filter upstream of the pump; it is design to be mounted downstream to prevent air leak from the filter, which had happened before.
Thanks again,
Barry
Old 01-21-2013 | 11:58 AM
FenderBean's Avatar
I believe they are a little longer
ORIGINAL: basimpsn
Old 01-21-2013 | 12:28 PM
757Driver's Avatar
My Feedback: (90)
Will correct. Thanks Barry!
Old 01-21-2013 | 06:15 PM
jws_aces's Avatar
My Feedback: (33)
Just lit my K180g for the first time yesterday....Smooth start with no problems. I am looking forward to flying it. Man I love the new set up. I also flying the k80e and love it.
The only thing I wish we could change is 3 cell lipo instead of Life 9.9v. This is not a Kingtech only deal. Seems like all new kero starts need the extra voltage. There are a lot more and lighter lipos out there that would work. I have been flying lipos for a couple of years and like them.
Maybe in the future.
Old 01-21-2013 | 06:23 PM
757Driver's Avatar
My Feedback: (90)
The life battery was chosen because of its reliability, stable chemistry and high discharge capability. I'm sure a lipo would be just fine as long as you could monitor it for swelling after each flight and remove it anytime it required charging. That said, most turbine airplanes require the batteries to be mounted forward and sometimes are inaccessible.
Old 01-21-2013 | 06:26 PM
757Driver's Avatar
My Feedback: (90)
Besides all that the KingTech is 12 ounces lighter than a Rhino or JetCat 180.
Old 01-21-2013 | 06:53 PM
Sorry Barry, was a quick install at the field and did not have a heater to soften up the 4mm tubing. It is a little tough gettin a little tube over a big nipple.
Besides, we had confidence that the pump would'nt shell out.
Old 01-21-2013 | 07:27 PM
marquisvns's Avatar
No worries Dale, just glad you Okie boys love KingTech, Jason, I don't think the weight difference is accurate, I believe we are a few insignificant ounces heavier.
Regards,
Barry
Old 01-21-2013 | 07:29 PM
dubd's Avatar
ORIGINAL: 757Driver
12 ounces lighter?????
Old 01-21-2013 | 09:01 PM
757Driver's Avatar
My Feedback: (90)
Honestly I can't speak to the JetCat. We did compare turbine to turbine with the Rhino. It did not account for total installation. I will make a video tomorrow.
Old 01-21-2013 | 10:00 PM
DiscoWings's Avatar
My Feedback: (76)
its important to compare between the jetcat 180sx and 180rx the 180 sx will weigh more than the rx, but the 180 sx also put out more power 45lbs.
Old 01-21-2013 | 10:27 PM
dubd's Avatar
The old Jet cat 180 is not in the same class at the K-180G or P-180RX. The old JC 180 was the same size as a P-200.
757Driver's Avatar
My Feedback: (90)
Sorry disco, I don't have a P-180 in any flavor. Do you have any you could scale all up with gear included? The 180g is impressive in all respects compared to the similar class Rhino.
Old 01-21-2013 | 10:36 PM
dubd's Avatar
I have a 180rx and k-180g and the 180g seems slightly heavier (few ounces) as Barry mentioned.
Old 01-21-2013 | 10:46 PM
757Driver's Avatar
My Feedback: (90)
Thanks Dub. Can you provide all up (installed ) weight of the 180rx and detail type of battery used?
Old 01-22-2013 | 12:31 AM
Alex48's Avatar
Im getting one to play with in a few days thats going into a SM F16, It'll be interesting to compare it side by side with the 180rx. Looking forward to trying it out as everyone seems to love them.
Cheers, Alex
Old 01-24-2013 | 10:17 PM
757Driver's Avatar
My Feedback: (90)
Got the 180G off the test stand. This is engine only but keep in mind the G model has the valves included. She's Purdy light at 3 lbs 13.5oz
Rhino weight tomorrow.
Old 01-25-2013 | 08:59 PM
757Driver's Avatar
My Feedback: (90)
Well its not 12 ounces but it is exactly 9 ounces lighter. The Rhino does have a FOD screen (forgot to remove it) but my point is that the KingTech is substantially lighter when comparing the same class engine with its required valves.
Also included is a picture comparing from Left to Right, 180G, 170G, 140G. The 170G and 180G are the same weight. The 140G is 1oz lighter and a bit shorter as the photo shows. I love these new engines.
ID:	1844355   Click image for larger version
Old 01-25-2013 | 09:22 PM
FenderBean's Avatar
hey 757 can you tell me if the 170 is smaller than the 180? I thought they were about the same size but from the picture its looks a little larger in diameter
Old 01-25-2013 | 10:38 PM
757Driver's Avatar
My Feedback: (90)
Exactly the same
