AirPower EV5U Programming Help
I have the older version of the 5 way valve with 3 of the 2 way valves. The previous owner had it all plumbed and working very nicely. He had the 5 way working the gear doors and brakes and was set in mode 3. One plug for gear and the other plug in an aux port. The other three 2 way valves all go to aux channels. He had it set up to unlock canopy open with one switch then close and lock with the same switch and had a delay programmed for the lock. I did get the program card from Todd at Dreamworks but he had no instructions on the older valve. I'm lost. Can anybody help? Thanks
