 oldest jet in the world to fly again >
Old 03-05-2013 | 10:06 AM
Default oldest jet in the world to fly again
http://www.dailymail.co.uk/news/arti...en-flight.html
Old 03-05-2013 | 11:22 AM
Default RE: oldest jet in the world to fly again
That's a beautiful plane.
ENT
Old 03-05-2013 | 12:44 PM
sysiek's Avatar
My Feedback: (176)
I wish ther is rc company who makes this turbine or twine edf jet for twine 90mm .
Old 03-06-2013 | 01:55 AM
Frank Sopwith's Avatar
I got one 1:5 scale....
very typical contours, exciting to fly,
Frank
ID:	1858765   Click image for larger version
ID:	1858766   Click image for larger version
Old 03-06-2013 | 02:22 AM
tow's Avatar
tow
I belive the oldest jet fighter in the world to be the ME-262...........???
Old 03-06-2013 | 02:46 AM
I believe so. Me262 or Me 163 komet, either one.
Old 03-06-2013 | 03:01 AM
Jim Cattanach's Avatar
ORIGINAL: tow
Yes, but are there any original examples flying now?
Old 03-06-2013 | 03:08 AM
ORIGINAL: Yann
Or maybe He280??
Best Regards,
=Adrian=
Old 03-06-2013 | 05:14 AM
GrayUK's Avatar
Komet 163 was not a true jet, it was rocket powered.
The HE280 first prototype was completed in the summer of 1940, but the HeS 8 intended to power it was running into difficulties. On 22 September 1940, while work on the engine continued, the first prototype started glide tests with ballast hung in place of its engines. It would be another six months before Fritz Schäfer would take the second prototype into the air under its own power, on 30 March 1941. The type was then demonstrated to Ernst Udet, head of RLM's development wing, on 5 April, but like its predecessor, it apparently failed to make an impression.
Engine problems continued to plague the project. In 1942, the RLM had ordered Heinkel to abandon the HeS 8 and HeS 30 to focus all development on a follow-on engine, the HeS 011, a much more advanced (and therefore problematic) design. Meanwhile, the first He 280 prototype had been re-equipped with pulsejets and was towed aloft to test them. Bad weather caused the aircraft to ice up, however, and before the jets could be tested, pilot Helmut Schenk became the first person to put an air powered ejection seat to use. The seat worked perfectly, but the aircraft was lost, and never found.
On 27 March, Erhard Milch cancelled the project. The Jumo 004-powered Me 262 appeared to have most of the qualities of the He 280, but was better matched to its engine. Heinkel was ordered to abandon the He 280 and focus attention on bomber development and construction.
The Whittle E.28/39 was delivered to Brockworth for ground tests beginning on 7 April 1941, using a non-flightworthy version of the Power Jets W.1 engine. These included some short "hops" of about 6 ft in height from the grass airfield. With these initial tests satisfactorily completed, the aircraft was fitted with a flightworthy engine rated for 10 hours use, and then transferred to Cranwell which had a long runway. On 15 May 1941, Gloster's Chief Test Pilot, Flight Lieutenant Gerry Sayer flew the aircraft under jet power for the first time from RAF Cranwell, near Sleaford in Lincolnshire, in a flight lasting 17 minutes.
The 262 first flew 18 July 1942 in Leipheim near Günzburg, Germany, piloted by Fritz Wendel. This was almost nine months ahead of the British Gloster Meteor's first flight on 5 March 1943.
However, i do not know of any original 262 airframes that are flying?
So, when this Meteor flys it will be "The oldest jet fighter in the world" unless someone gets a HE262 going..... or a Whittle!.
Paul G
Old 03-06-2013 | 08:53 AM
hi
i do not post that much on rcu
the me262 made by stormbirds.com to my understanding they got original werknr from the messeschmit foundation.
because they reversed engineerd an original .
only the engines are prat&whitney .
Old 03-06-2013 | 09:36 AM
tow's Avatar
tow
If we are talking oldest jet still flying it still is the 262.. Reason why there aint any airworthy originals today should be obivious. If the coin flipped the other way ther would`nt be any Meteors flying today either....... (No politics Please)
Old 03-06-2013 | 01:10 PM
GrayUK's Avatar
How's the 262 the oldest still flying ?
Are there any?
Old 03-06-2013 | 02:25 PM
Vincent's Avatar
My Feedback: (61)
For the record the first airframe to fly with a turbo jet engine was the German Heinkel HE 178. It flew on Aug 8 1939.
Vin...
Old 03-06-2013 | 02:32 PM
roger.alli's Avatar
ORIGINAL: GrayUK
The Whittle E.28/39 was delivered to Brockworth for ground tests beginning on 7 April 1941, using a non-flightworthy version of the Power Jets W.1 engine. These included some short ''hops'' of about 6 ft in height from the grass airfield. With these initial tests satisfactorily completed, the aircraft was fitted with a flightworthy engine rated for 10 hours use, and then transferred to Cranwell which had a long runway. On 15 May 1941, Gloster's Chief Test Pilot, Flight Lieutenant Gerry Sayer flew the aircraft under jet power for the first time from RAF Cranwell, near Sleaford in Lincolnshire, in a flight lasting 17 minutes.
So, when this Meteor flys it will be ''The oldest jet fighter in the world'' unless someone gets a HE262 going..... or a Whittle!.
Paul G
Thanks for the information Paul.
Setting aside the silly argument for a moment, how brave were the WWII test pilots??
"Meanwhile, the first He 280 prototype had been re-equipped with pulsejets and was towed aloft to test them. Bad weather caused the aircraft to ice up, however, and before the jets could be tested, pilot Helmut Schenk became the first person to put an air powered ejection seat to use. The seat worked perfectly, but the aircraft was lost, and never found."
Helmut must have had big ones!!
Roger
Old 03-06-2013 | 03:03 PM
SJN
ORIGINAL: GrayUK
Are there any?
ID:	1859003   Click image for larger version
Old 03-07-2013 | 12:52 AM
Aren't these "new build" replicas?
Best Regards,
=Adrian=
Old 03-07-2013 | 02:37 AM
My Feedback: (118)
Not trying to whiz in anyone's Cheerios.  This plane was credited for only 14 V1 kills of the over 10,500 V1 rockets launched at Britain during the war.  Granted it was the threshold of jet technology but they canned this model when the V2 came out because it couldn't even get close to shooting one down.  Still a magnificent piece of history.  Glad we could enjoy the ressurection.</p>
Old 03-07-2013 | 03:17 AM
tow's Avatar
tow
The heading on this thread says "Oldest jet in the world to fly again"....... It doesn`t say "still flying". My mistake Whilst the Meteor was a great achievment for its time, and I`m taking my hat off for the people who manage to keeping an example airworthy, it`s been stated not to be the oldest in the world. That was my point! . Frank Whittle were the first to patent the turbojet engine. In the time German engineers were way ahead of that. The Me-262 were the first true jet-fighter to see service and combat. We can agree on that I think. No belitteling of others.
Old 03-07-2013 | 03:22 AM
ORIGINAL: pmerritt
At the speed of a V2 rocket, the only thing that would have been able to shoot it down would be a guided missile.
I think the first air to air missile came into service in 1956 called the Aim-4- Falcon with the US airforce.
Old 03-07-2013 | 07:16 AM
Quikturn's Avatar
My Feedback: (12)
ORIGINAL: Vincent
Vin...
+1
I was helping my daughter on a timeline in aviation project for school and discovered the HE 178 was the first jet aircraft to fly and the ME 262 is the first jet fighter to fly.
Her school notes made no mention of any German accomplishments and gave Great Britain credit for development of the turbine engine when in fact it was independently co-developed by Great Britain and Germany around the same time. I found this disappointing and so we made sure to set the record straight.
As a side note, much of the Saturn V rocket came from German know how but you don't find much credit for that either.
Old 03-07-2013 | 09:44 AM
tow's Avatar
tow
ORIGINAL: Quikturn
ORIGINAL: Vincent
Vin...
+1
This isn`t the only example of tweaking the history; One has to remember there`s always the winning part in any war who writes the history-books. Sadly but true. One example, It turns out my grand-children has no idea who Winston Churchill was. Most of the material regarding WW 2 is taken out of the school-books. This in spite of the fact that my country were occupied by Nazi-Germany for five years! I still think German scientists and engineers should have due credit for their accomplishments.
Old 03-08-2013 | 02:34 PM
tow's Avatar
tow
Just one to watch:
Enjoy :-)
http://www.youtube.com/watch?v=QTxGDI2-wDs
